Frank Spurlock
I recently replaced the 25 yo 1/2 hp submersible pump in my 38 ft deep 4 inch well. The new Goulds 10GS05 pump was placed at 34 ft depth (same as old); the water level was 27 ft. I also installed a new Franklin QD control box. The 230 Volt pump motor is a Centipro. The new pump overpumps the well, and sucking air sounds occur followed by motor thermal overload tripping approx 30 seconds after startup. The pump distributor guy suggested installing a brass ball valve and partially closing the valve to increase effective head on the pump and reducing discharge. I did this. Before the the ball valve install, the pump motor was drawing 6.3A (above SFA) at well head pressure of 40 psi,corresponding to a Total Dynamic Head at pump of 27 feet +40*2.3 = approx. 120 feet by my calcs. I determined the approximate desired pressure at the well head by (1) selecting 10 GPM as the desired discharge (center of discharge curve = approx design discharge for the 10GS05), (2) determining the corresponding Total Dynamic Head of 180 from the Goulds pump discharge curve, and (3) backcalculating the desired well head pressure of approximately 66 PSI. I adjusted the ball valve accordingly, and seem to achieved the desired flow rate since my pressure tank 30 cut-in/50 cut-out drawdown volume of 27 gallons is refilled in about 2.5 minutes and everything seems okay so far. Oh, I also installed a pump-tec 231-insider pumpsaver for overpump/deadhead protection of the pump.
I have 2 questions:
1. Given that I really don't want to replace the incorrectly sized pump, does this all seem a reasonable way of managing the overpumping problem?
2. The pump motor current draw at the circuit box as measured by a clamp-on ammeter is 5.9 A for the 70 psi well-head back pressure ball valve setting. This lies between the Centipro motor FLA and SFA specifications of 5.3A and 6.1A, respectively. I don't really understand FLA and SFA very well. The pump distributor guy seemed to think the draw should be between 4.5 and 5 amps, and was somewhat troubled by this apparently high current use.
Any comments/suggestions? Thank you very much.
I have 2 questions:
