Manabloc & Van guard PEX opinions
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by mamato2girls, Mar 21, 2007.
  1. mamato2girls
    mamato2girls New Member
    Mar 21, 2007
    Arkansas
    I am about to install a Manabloc system with Vanguard/Vanex PEX tubing in my new house. I just stumbled across your site & I love it. I was wondering if anyone had used Vanex before. I am still nervous using a product I'm not familar with. Not about the installation, but about safety, leaching from lines into drinking water, etc. I'm a mom so this is the way my mind works! I am a stay at home mom who grew up the daughter of a builder. My dad (who passed away last month) taught me how to do just about everything when it comes to building a house. I am very proud to be finishing the house we started together using everything he taught me. I think he would approve of pex. He worried about me sweating copper.
    Thanks for your help!
  2. spresco
    spresco New Member
    Jan 28, 2007
    I am doing the same thing. Not a professional plumber. Just started making the main connections to the Manabloc. PEX is alot stiffer than I would have thought. I am following the guidlines as far as bend radius but it is tough to keep it in place. I bought a long handled crimper that has interchangable heads to save money. It takes two hands so it is harder to get a good crimp.
  4. mamato2girls
    Mar 21, 2007
    Arkansas
    That sounds like the crimper that I am planning to buy. I don't want to spend $225 for the others. I thought the same thing about the flexibility. It doesn't appear to bend as well as the pictures suggest. I guess it may take more slack than we intended. Good luck with your installation. We should get started the first of next week. We're going to do drains this weekend.
  5. jrseaberg
    jrseaberg New Member
    Dec 24, 2006
    manage a small business facility
    central IL
    first tiime PEX user...
    I just ran five 1/2" PEX lines from my basement to 2nd floor bathroom. I really like the thought of no joints in the walls/floors. The PEX is more rigid than I anticipated, but it did not cause me any problems; it made the bends from basement ceiling joist space into wall stud space and then into 2nd floor joist space with no problems. (I did find it easier to pull with another person helping at the other end.)
    I bought a Souix Chief crimping tool from ******* (like Lowes, Home Depot, etc.). Dual head, 1/2 and 3/4", for 89.00. I have used it for only probably 15 - 20 connections so far, but I have not had any failed crimps to this point. It is adjustable, and performs more than adequately in my opinion.
    I ran it using manifolds, with a single valve on each of the supply lines to the manifolds, and used PEX plugs for the unused outlets. I did terminate each line with its own shut-off valve at the fixture.
    I was not terribly impressed with the PEX copper stub outs; I wasn't able to get them mounted as rigidly in the wall as I would of liked, but definitely workable. (There is probably a proper method of doing this, but I don't know it.:p ) If doing this again, I would probably have used a PEX to 1/2 pipe adaptor with the "ear " mounting holes, that I would screw into blocking, like I did for the two shower heads.
    I am no where near being a pro at plumbing, and probably "just" qualify as a DIYer. I will continue to use PEX as I re-plumb my house.
    Just my thoughts....
    Have fun!
    Jim
  6. mamato2girls
    Mar 21, 2007
    Arkansas
    You sound just like me!!
Similar Threads: Manabloc guard
Plumbing Forum, Professional & DIY Advice Pex Vanguard Manabloc manifold ... which type and diameter? Feb 17, 2012
Plumbing Forum, Professional & DIY Advice Vanguard Manablock pex manifold Nov 23, 2009
Plumbing Forum, Professional & DIY Advice PEX Manifold sizing (Vanguard MANABLOC) Jun 29, 2007
Plumbing Forum, Professional & DIY Advice Pressure testing PEX lines leading away from a ManaBloc? Feb 23, 2016
Plumbing Forum, Professional & DIY Advice Manabloc supply lines blow off Feb 19, 2016
