make bladder a holding tank?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jeeper1, Jul 7, 2012.
  1. jeeper1
    jeeper1 New Member
    Jul 7, 2012
    Spring Branch ,Tx.
    so Im new here and as my first thread I have a good question....so far i have a 380 ft submersible well with a pressure tank. The pump is having issues building pressure. What i have done is lowered the shut- off pressure to about 20 and taken most of the air out of tank. Then I added a shallow well pump and bladder tank that supplies house, set this at 55 lbs. My question , is this a proper way of using pressure tank as a holding tank? I guess I really need to change the down-hole pump and put in a surface tank for the long haul.....
    Thanks for any replies.....:cool:
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    The answer is no. A tank that is designed only for pressure should never be subjected to a potential vacuum.
  4. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    That is a pretty good Bandaid on a bad situation. The problem comes when the booster pump is putting out more than the well pump can give it. You shouldn't need the booster if the well pump was working as it should. Your well pump is not puting out what it should or you have a hle in the well pipe. If you don't fix the real problem, it won't be long until you don't have any water to boost.
  5. jeeper1
    jeeper1 New Member
    Jul 7, 2012
    Spring Branch ,Tx.
    actually seems to be working preety good for the time being......
  6. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    It's a bit like using duct tape to stop the oil leak on your truck.
    It might work for a little while, but you will be much better off just fixing it the right way.
Similar Threads: bladder holding
Pumps and Tanks Well Forum & Blog. Water is life. Bladder tank and holding tank Nov 14, 2013
Pumps and Tanks Well Forum & Blog. Water is life. Wrong Well tank Bladder vs hydro-pneumatic Sep 19, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Pump is short-cycling. Tank bladder issue? Aug 30, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Bladder Tank Down Aug 18, 2016
Pumps and Tanks Well Forum & Blog. Water is life. Water presssure / bladder tank problem and fix Jul 28, 2016
