Main Water Supply Line
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by cybervex, May 5, 2008.
  1. cybervex
    cybervex New Member
    Feb 26, 2008
    IT Systems Administrator
    Southfield, MI
    On my house rebuild project I am thinking of changing the main water line from the house to the outside turn-off in the front yard. It currently has 3/4" and I would like 1"
    How does this normally work? Do I dig it up to the turn-ff and replace it myself or do I run it to the turn-ff and the city hooks it up? The water is turned off right now and the city is going to have to dig it up to replace the pipe down to the turn-off as it is bent.
    If it helps this project is in Southfield, MI. The turn-off is in the front yard approx. 25' from the front of the house.
    Thanks in advance
    Jay
  2. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    Well, why do you want to replace it? just to go up to 1" or is the line bad? you really won't get much by going to 1". most cases you dig it up and connect it yourself but you may need a permit.
  4. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    Won't going up to 1" supply more GPM. I own another house on the same block and tested the pressure/flow rate with a tester and it showed 45PSI/6GPM, this house has 3/4".
    Would the 1" supply not give me the added flow? It would be easier to replace it now before I install the water meter and the copper to my manifold.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    The flow will be regulated / affected more by the meter size and the homes plumbing than the line between the house and street, as far as changing from 3/4 to 1, unless it is a long run...how far is it from the street to the house?
  6. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    Approx 50' from turn-off to main accross the street. I am not sure what size it is from the main to turn-off a neighbor was telling me it is 1 1/4"
    I am assuming that there is a 1" meter as if my permit was for a new build house I would HAVE to put in 1" according to the water department told me last year.
  7. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    If you have a 1" meter, then a 1" line would be proper. The size of the meter dictates the size of pipe you need. Going to a larger size would only help if you had a very long run by reducing friction, but in your case the difference would be too small to note and would be totally unnecessary.
  8. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    Here's the thing. I do NOT have a meter yet. I have the old 3/4 line from the old house. This was a fire damaged house that we ripped down and rebuilt. The only thing left from the old house is one peice of the foundation and the water and sewer. When we bought the house the water meter had been destroyed from freezing over the winter.
    I can either use the 3/4" or up it to 1". I was hoping that the 1" would deliver more water.
    If I get 6GPM from the city on a 3/4 line wouldn't I get more from a 1"?
    So before I call the city to order a water meter I figured I would ask you folks if its worth the $300 in copper to change to 1". Will I notice the difference in volume?
  9. jadnashua
    If the line to the supply is larger, then yes, your 1" line and meter will supply more volume. 6gpm is pretty anemic, actually, for a 3/4" line - the pressure would have to be really low to restrict it to that volume. Note, an average 1/2" bathtub filler valve will flow around that by itself, and if you turned anything else on in the house if all you had was 6gpm, you'd really notice it.
  10. cybervex
    cybervex New Member
    Feb 26, 2008
    Southfield, MI
    The 6GPM is terrible. We at the end of the line in the city. Last year when I hooked up the pressure tester we only had 35 PSI, the city has been slowly turning up the pressure over the last year, now we have 45PSI but the flow is not good. I think the city needs to upgrade our lines. I won't hold my breath!!
    Thanks for all the comments
  11. arfeller
    arfeller Member
    Aug 25, 2007
    Port Angeles, WA
    I have similar question
    I currently have 1/2" pvc supply line to my house. The meter and main supply line is approximately 50 feet from my house.
    At some point under ground the pvc switches over to galvanized pipe and it comes into the house as galvanized. I actually thought it was all galvanized until i was digging a trench for my gutter drain and found pvc water line.
    Anyway... I am going to replace all the galvanized inside the house (the pipes are starting to leak from corrosion) with PEX and thought it might be a good idea to upgrade my supply line size also. 1/2" sure looks small to me. They used that 1/2" white plastic with flared ends so they fit inside each other without fittings.
    I am not sure what size my meter is. Have to uncover it a bit. sediment has covered the pipes under the meter. But what is "normal" for supply lines? Is there a rule of thumb?
  12. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    arfeller I would upsize my house main to 1". 1/2" is very small.
    I would also start a new thread so you don't hijack this thread.
  13. Plumber Jim
    Plumber Jim Member
    Mar 29, 2008
    3/4" would be just fine. If you are getting a new meter and the supply to your meter yoke is at least 1" and you have the money then sure upgrade the old one to 1".
Similar Threads: Main Water
Plumbing Forum, Professional & DIY Advice Add garden water valve/spigot to irrigation main line Wednesday at 12:09 AM
Plumbing Forum, Professional & DIY Advice Main Water Feed - 20psi Pressure Drop When one Fixture is Open Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Main Water Line Basement Entrance - Does this look OK? Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Cold water supply line connected to cast iron main stack? Oct 27, 2016
