main water line break
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by flabbb, Sep 16, 2007.
  1. flabbb
    flabbb New Member
    Sep 16, 2007
    the main water to the house broke. it is halfway between the cutoff and the house. the line is nearly cracked in half ( 3/4" copper ). can i fix it and if so how ( cut out problem and/or solder a sleeve over the crack , or some other solution ? ). or should i replace the entire line ( ~ 40' from street to house , including running under the sidewalk ).
    thanks,
    scott
  2. patrick88
    patrick88 Plumber
    Sep 3, 2007
    plumber
    Webster Ma.
    Replace the whole line. If it cracked in that one spot what makes you think it will not crack in another. It is always best to think of what will happen next. The pipe is old and worn so replace it and never have another problem with it again
  4. TMB9862
    TMB9862 New Member
    Nov 12, 2006
    How old is the service? If it's ten years or older I'd replace the entire line. If it's newer then that it was probably just a rock in the wrong place that made it leak and I'd patch it. Most of the time if you do things by the book and get the water district out there they won't allow you to patch an older line as it's just going to keep leaking.
  5. Cass
    Cass Plumber
    Nov 12, 2005
    If you are in an area that has water that attacks copper you may want to replace the whole line BUT K copper is very heavy duty and if it is only 10 years old I would cut out 2' of pipe with the break in the middle and just repair the break with 2 pack joint couplings and enough new K copper to do the job.
    Find out if it is K copper.
  6. flabbb
    flabbb New Member
    Sep 16, 2007
    water line
    thanks all. the house was built in the early 40s. they had a remod in the 60's but i don't think it had anything to do with the front ( where the water line is ). we have been in the house since 91 so thats 16 years. could be the original pipe from the 40's ? or sometime between, but at least 16+ years.
  7. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    I think it would be in best interest to replace.
  8. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Point worth mention.
    Home Depot/Lowes do not carry type K, which is necessary for underground mains.
    Plumbing supply has it.
  9. Gary Slusser
    Retired
    I'd use 200 psi rated PE pipe in a roll and a SS fitting underground and brass in the house.
Similar Threads: main water
Plumbing Forum, Professional & DIY Advice Add garden water valve/spigot to irrigation main line Yesterday at 12:09 AM
Plumbing Forum, Professional & DIY Advice Main Water Feed - 20psi Pressure Drop When one Fixture is Open Dec 23, 2016
Plumbing Forum, Professional & DIY Advice Water Main inside has a slow leak Dec 14, 2016
Plumbing Forum, Professional & DIY Advice Main Water Line Basement Entrance - Does this look OK? Nov 25, 2016
Plumbing Forum, Professional & DIY Advice Cold water supply line connected to cast iron main stack? Oct 27, 2016
