Main Stack Connection
Mark C
Hi All,
I am doing a large addition with 4 fixtures, toilet, whirlpool tub, walk-in shower and lav. The main stack is 30' away from the farthest fixture (toilet).
I had an outside cleanout, to the main stack, installed before this project started. Indoors, the main stack has a cleanout, that has never been used.
I am wondering if I can put a male 4" connector on the cleanout. Then run up some 4" pvc and put a Y on it. Then connect the new drains into it.
Or should I just cut the 4" main and put PVC and a Y onto it? The cleanout and main stack are next to each other.
Thanks, Mark.
cleanout
Whether the cleanout has ever been used or not is not the question. It is a cleanout and as such is not supposed to be used as a connection point, especially if it is a two way cleanout fitting in the main line.
GrumpyPlumber
Licensed Grump
Licensed Grump
Exactly...unless it's an E.C.O. - you add a new E.C.O. at the end of a wye that extends from the original place of the cleanout...also...remove the old cleanout...you shouldn't put a threaded fitting into it.
If removing it turns into a nightmare...call a plumber, thats your waste main.
