Main shutoff location for the well.
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by jbhis, Aug 17, 2006.
  1. jbhis
    jbhis New Member
    Aug 17, 2006
    Firefighter
    West Michigan
    A house that I'm considering buying has a private water supply and is six years old. I had the home inspected and the inspector said that the main shutoff should be located between the pressure tank and the entry supply piping. Several people have said that this is incorrect.
    What do you think?
    I've included some pictures of what I'm talking about.
  2. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    Your cut off needs to be after the tank and switch. This way you don’t burn stuff up. by looking at your pic it looks like you have 2 shut off’s that feed the house. One is the yellow and one looks red. Every thing looks good in the pic but the wire that’s loose off the presser switch to the hole in the wall and the other wires floating around. But they are nothing to think about.
    <edit> PS I missed something…
    For got about a ground wire. Your electrical panel should have a copper wire that goes to the copper pipe with in 5 feet of where it enters the wall and it should also have a jumper to bond after the tank because the tank T can be removed for replacement and for repairs.
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    It looks good to me. Never put a valve between the pump and tank/pressure switch. If someone closes it, poof goes the pump.
    bob...
  5. jbhis
    jbhis New Member
    Aug 17, 2006
    Firefighter
    West Michigan
    Thanks guys, I really appreciate it.
Similar Threads: Main shutoff
Pumps and Tanks Well Forum & Blog. Water is life. Leaking main shutoff valve on a well Oct 10, 2007
Pumps and Tanks Well Forum & Blog. Water is life. Running line for hose Bibb off well main Jan 3, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pump won't maintain pressure Feb 4, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Well Maintenace Sep 4, 2014
Pumps and Tanks Well Forum & Blog. Water is life. Ejector Pump running in basement after water usage on main floor May 26, 2014
