Main shut-off replacement
mikek753
California
hi all,
The outside in house main gate valve is broken and need to be replaced.
So I started this by getting new parts.
When I assemble everything I got leak from Telescopic Repair Coupling 1-1/4" that I got from osh
http://www.osh.com/Osh-Categories/Plumbing/Rough-Plumbing/Pipes-&-Fittings/PVC-Fittings/NDS-Quik-Fix&#8482-Telescopic-Repair-Coupling,-1-1-4-Inch,-IPS-Hub-x-IPS-Spigot,-PVC,-White,-12-Case/p/6506190
This's what I had before:
https://goo.gl/photos/UECZndNxGgxvqd1k9
and how it's now
https://goo.gl/photos/sLQBurqRqKBRyTZc8
Those were my options and I used marker with red arrow
That telescopic is leaking - the inner o-ring isn't stopping water as expected
How I can fix this?
Thanks
Mike
Montreal, Canada
Looks like you didn't clean the pipe from the ground that touches the "Telescopic Repair Coupling".
You should have prepared that surface smooth with wet sanding it down.
Purchase the materials once more, and try another attempt at the repair.
Bluebinky
Des Moines, WA
It's more work, but I would dig down to where the pipe goes horizontal. How much digging is hard to say, but with enough exposed, you might be able to cut off the 90 and then be able to glue things up with regular fittings. It just depends on what's down there.
