main service to the house
Mike.Schwank
Recently found out that on the system servicing out house we have:
6inch main that has one, 1 inch branch (width of street) that then has a T to two meters and then then from each meter goes a 1" or 3/4" service to the each house. both houses are about 100-150 feet from the meter(s).
because of low pressure I put in a pump (1/2 hp) and bladder tank. My neighbor gets a pressure drop when this kicks on...
is it normal to service two 3-4 bedroon houses from one 1" pipe (black PVC)?
thanks.
GrumpyPlumber
Licensed Grump
Licensed Grump
a 3/4" line will service up to 2 bathrooms, laundry,silcock and a kitchen.
for two residences this size, you'd need 1-1/4" minimum.
You'd do well to call the local DPW and inquire.
GrumpyPlumber
Licensed Grump
Licensed Grump
Actually, on second thought I stand corrected...1" should be fine as long as there aren't any more fixtuires than I presumed...furthering the idea that you should call the DPW regarding the pressure.
pipe
It was done here for years, but at least one city has discontinued the practice. Your neighbor's experience is the same as what happens when many people in a neighborhood decide to add booster pumps to their systems. If there is not enough water to feed both houses, then there is definitely not enough to feed two when one of them has a pump sucking the water out of the pipe. I think the water company could make you remove it because of the degradation of the neighbor's water supply.
