Hello, I recently pressure tested my lines at the faucet nearest the main line from the street. The pressure on the ORBIT gauge reads 45PSI. Isn't the average pressure supposed to be between 55-70PSI.
Problem is, I can't find the damn pressure regulator anywhere starting at where the line comes in at the street (meter). The irrigation valves look to be the first contact with the water line. Nowhere near the water heater either. Where is the pressure regulator usually located? Local water authority says the pressure is between 70-100PSI in my neighborhood, so there must be regulator somewhere on the line, but where?
Thanks
Thanks
