Main Drain Pipe Question
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Vince B, Nov 30, 2008.
  1. Vince B
    Vince B New Member
    Oct 2, 2008
    Hello all,
    I wanted to know if it would be ok to cut the subfloor as marked in the red area.
    I have attached a picture to better illustrate. The picture was taken from the basement and is the main drain pipe which also goes straight up and attaches directly to the vent stack. I need to get access to the drywall that is behind there but didn't want to start cutting if it will adversely affect the ABS pipe movement, integrity, etc... Any thoughts would be greatly appreciated.
    Thank you for your time,
    Vince B
  2. kingsotall
    kingsotall Plunger/TurdPuncher
    Aug 17, 2008
    Hand copper part cleaned ready to go
    Flagstaff, AZ Sitting on an upside down 5 gallon b
    Seems fine to cut the subfloor section out. If the pipe moves or requires stability strap it to the joist with some p-tape. (plumbers tape)
  4. rmelo99
    rmelo99 Network Engineer
    Jul 7, 2006
    Network Engineer
    Looks like there is metal plumbers strapping already around the pipe. Is that right?
  5. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It appears there is by the upper elbow.
  6. hj
    floor
    As long as you do not cut the pipe, there is no reason you cannot do what you are asking. That section of floor has absolutely nothing to do with the drain line.
  7. Vince B
    Vince B New Member
    Oct 2, 2008
    Yes, that is a metal strap on the upper elbow so I should be good to go.
    Thank you all again for your honest and professional input.
    Best Regards,
    Vince B
Similar Threads: Main Drain
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Jog in Main Drain Sep 18, 2016
Plumbing Forum, Professional & DIY Advice Toilet drain to merge in offset part of main stack? Aug 10, 2016
Plumbing Forum, Professional & DIY Advice Main drain cleanout worn can't get a wrench on Jul 3, 2016
Plumbing Forum, Professional & DIY Advice Swimming pool main drain Apr 24, 2016
