Main drain line lining, good or bad?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Galina, Aug 19, 2009.
  1. Galina
    Galina New Member
    Aug 18, 2009
    Massachusetts
    Hi, I have this problem with roots in my mail drain line and, surprise, surprise! try to avoid $6-8 K for replacing the pipe; found special lining (plastic sleeve that goes into the pipe) which prevent root growth, does anyone knows anything about it? does it work? will it still be possible to use the motorized snake for the main lines if case of clogging?
    Any information is very welcomed!
  2. FloridaOrange
    FloridaOrange Plumbing Designer
    Dec 2, 2005
    Plumbing Designer
    SW Florida
    I've seen a system that uses a hybrid figerglass lining that is steam activated. That system is and has been used to repair existing lines without digging up the whole drain system. Is this what you are looking at?
  4. hj
    lining
    If the liner just slides into the sewer, then roots will still grow behind it and deform the liner. IF it is epoxy bonded to the pipe, it SHOULD minimize root intrusion, but since roots have IMMENSE power, there is still a possibility that eventually they could dislodge it. You also have to be certain that the roots are completely removed from the pipe so the liner makes perfect contact with the entire interior of the pipe. Like many other things, you do have to accept the finished product on faith, because you cannot check to see if the bonding occurred or if it occurred on the entire pipe. You might also have a problem if there are any connections to the pipe within the lined area.
  5. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    Why not just fix it? Find where the roots are (hire someone with s camera and locater) and if it's not more than 7 feet or so deep, grab a shovel...
    Jason
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    Sewer drain lining !
    THIS IS A VERY GOOD SYSTEM IF INSTALLED BY GOOD PEOPLE,
    I HAVE WORKED WITH IT AND SEEN IT USED ON MANY HOMES TO STOP "ROOTS"
    AND REPAIR BROKEN OR CRACKED SEWER PIPE !
    http://www.perma-liner.com/
  7. pjonesCET
    pjonesCET New Member
    Aug 19, 2009
    Retired Electronics Tecgnician
    Martinsville
    My mother and I live in a 62 year old rental house. and for years we had problem with roots with the original teracota pipes. Then when we ended up the only house left in our block the owner put in special Cast iron pipe withe special flanges that prevent root growth. we went for years. Then city came along several years ago and because of road widening broke up sections of the pipe both at house and at road edge and replace with plastic pipe and used ruber unions with stainless steel straps. Now we haven't nothing but trouble with roots.
    If your going to replace pipes for roots get those pipes I refer to so that roots have no way of getting.
  8. hj
    pipe
    I have never heard of or seen any cast iron sewer pipe with flanges of any kind, much less root proof flanges, (which any would be if they were available).
  9. SewerRatz
    SewerRatz Illinois Licensed Plumber
    Nov 20, 2008
    Chicago Illinois Licensed Plumber
    Chicago, IL
    I have seen these liners fail. A city here been lining home owners sewers to help stop infatuation. In a few of these homes they needed up digging and replacing the whole sewer due to the liner sliding. Also the cost of lining a sewer is not cheaper than digging. The advantage you get is you do not need to do a lot of landscape restoration which will save a few bucks there.
  10. Galina
    Galina New Member
    Aug 18, 2009
    Massachusetts
  11. jadnashua
    I don't know much about them, but I've read about machines that can essentially push a pipe through the ground and you only need an access hole at each end. No idea how well they work, their limitations, or what it costs (or if anyone in your area has the machine and knowledge to use one). But, might be worth looking at if you don't want to tear up your gardens and other landscaping. Probably wouldn't work if you have a lot of rocks, but with normal soil, probably.
Similar Threads: Main drain
Plumbing Forum, Professional & DIY Advice Main Stack as vent for tub and shower drain Mar 8, 2017
Plumbing Forum, Professional & DIY Advice Adding Softener Drain to Main Drain Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Jog in Main Drain Sep 18, 2016
Plumbing Forum, Professional & DIY Advice Toilet drain to merge in offset part of main stack? Aug 10, 2016
Plumbing Forum, Professional & DIY Advice Main drain cleanout worn can't get a wrench on Jul 3, 2016
