Main drain depth exiting cottage for septic line connection
Discussion in 'Plumbing Code Questions' started by chuck b, Jun 23, 2011.
  1. chuck b
    chuck b sea-bee
    Jan 19, 2011
    levering, michigan
    Have smallish 650 sq. ft. cottage in Northern Michigan - seasonal for non-winter months.
    Replumbing entire DWV system, and need to know what depth to exit cottage for future new septic system (elevated-engineered system) connection.
    Have heard conflicting stories, e.g. top of (3" sch. 40 pipe in my case) at least 8" below ground level.
    Please advise. After exiting, will travel short distance to dousing tank - grinder pump then some 300' to field.
    Thanks.
  2. hj
    You install the plumbing inside the building, and then they install the septic tank wherever it has to be so the pipe can be connected. I have had tanks 18" below the ground, and also 10' down when there was a basement.
  4. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    I would put it at least 12 inches deep so your tanks will be below the ground surface. The depth of the tanks should not matter unless you have bedrock near the surface or a very high water table that could cause installation problems etc. Since you are pumping the sewage the depth is not as important. Sometimes for a gravity system you would have to keep the plumbing high if the drain-field was being installed in a raised mound or required to be installed ultra shallow because of the water table etc.
  5. hj
    Since the opening in the tank is usually 12", OR MORE, below the top, a pipe 12" deep would put the tank at or above the ground level.
Similar Threads: Main drain
Plumbing Code Questions Underground Branch Line Ok to Cross Over Main Waste Line? Jan 21, 2015
Plumbing Code Questions Main Vent or Stack Vent Required? Sep 16, 2013
Plumbing Code Questions Creating an S-trap to raise the height of a bathroom sink drain outlet Apr 16, 2017
Plumbing Code Questions Siphons on drains Feb 23, 2017
Plumbing Code Questions Washing machine standpipe-- wye for drip drain line? Jan 11, 2017
