Main Disconnect Seperate from panel?
Discussion in 'Electrical Forum discussion & Blog' started by Nate R, Jun 3, 2009.
  1. Nate R
    Nate R Member
    Jan 11, 2007
    I perform R&D testiing at small engine manuf.
    Milwaukee, WI
    When you have an outdoor main disconnect; and the main panel is separate from that (indoors), is the main panel treated as a subpanel as far as neutral/ground bonding?
    Where in the NEC do I find this?
    Just looking for a quick answer. I was asked this, and I don't know the answer.
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    Yes, the panel would be treated as a "sub-panel" with the neutral not bonded.
    Here is the NEC section:
    250.24(A)(5)Load-Side Grounding Connections. A grounded conductor shall not be connected to normally non–current-carrying metal parts of equipment, to equipment grounding conductor(s), or be reconnected to ground on the load side of the service disconnecting means except as otherwise permitted in this article.
  4. Nate R
    Nate R Member
    Jan 11, 2007
    Milwaukee, WI
    Thanks! My brother is a home inspector. He's doing a pre-sale inspection for the seller to be able to show buyers, and to tell the sellers what may come up and be an issue, etc. He asked me about this, but I wasn't sure.
    And thanks for the code section for the quote! :D
  5. VinceS
    VinceS New Member
    Jul 16, 2009
    That's the problem with home inspectors!
    "Thanks! My brother is a home inspector. He's doing a pre-sale inspection for the seller to be able to show buyers, and to tell the sellers what may come up and be an issue, etc. He asked me about this, but I wasn't sure."
    Nate R, I realize it was your brother who asked the question, but doesn't that strike you as being a major problem? Your brother is a home inspector and he doesn't know the answer to that question? Unfortunately I've used home inspectors on at least two home purchases, and although they had slick marketing and reports they simply did not know what they were talking about. Unfortunately your brother seems to be in the wrong line of work...that is if he cares about providing a valuable service to his customers.
  6. hj
    inspector
    At least he knew enough to ask the question. Most would not bother with it unless it was something that hit them between the eyes with a 2x4.
  7. drick
    drick In the Trades
    May 16, 2008
    Ain't that the truth!
Similar Threads: Main Disconnect
Electrical Forum discussion & Blog Main Disconnect Question Jan 19, 2009
Electrical Forum discussion & Blog Main Power Supply Move Jun 23, 2016
Electrical Forum discussion & Blog Extending ground wire from main panel Jun 11, 2016
Electrical Forum discussion & Blog Two MC cables into one knockout on main panel? Jun 11, 2016
Electrical Forum discussion & Blog Does a sub panel in attached space need a main breaker? Feb 20, 2015
