Main Disconnect Question
Discussion in 'Electrical Forum discussion & Blog' started by jaxbldginspector, Jan 19, 2009.
  1. jaxbldginspector
    jaxbldginspector New Member
    Mar 19, 2008
    What are the requirements for a main disconnect on 200 amp service?
    Is a disconnect required at the meter or will a 200 amp panel with a disconnect be correct? The panel box is not located on an interior wall right behind the meter, it is at least 20 ft away from the meter. The main wire going to the panel would always be hot with no way to turn if off without calling the power company or pulling the meter.
    Thanks for any input.
  2. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    I hate to seem like a jerk, but you are the building inspector. What do your local codes say?
    According to the NEC you would need a disconnect "installed at a readily accessible location either outside of a building or structure or inside nearest the point of entrance of the service conductors."
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Petey
    Ever seen a "building inspector" that had enough sense to get in out of the rain?
  5. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    Mike , you know we will turn you down anytime! Rain or Shine. And enjoy it! Mel
  6. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    See here is one that admitts he will stay out in the rain even if it is just to turn someone down.
    Mel We all know that the inspectors are like the mail carriers. Neither rain or snow will keep an inspector from doing his job.
  7. jaxbldginspector
    Mar 19, 2008
    My response.
    If my name was Obama I guess you would think I was the President of the United States?
  8. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    In MA the main wires going to the panel are always hot unless the meter is pulled
    Are you the President?
  9. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I have absolutely NO idea what this means. :confused::rolleyes:
  10. codeone
    Sep 5, 2008
    North Carolina
    Maybe Imposter? Fraud? ETC?
  11. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Oh. DUH!!!!!!!!! :eek: :eek:
    No jax, but if you come on a home improvement message board with a name like yours why would we have reason to think anything else???
  12. hj
    disconnect
    Here, there MUST be a main disconnect at the meter so the power company can disconnect the house if they wish to avoid power surges into the building. IT can be a simple disconnect, or the house panel with a main disconnect, but must be able to disable the entire building.
  13. Alectrician
    Alectrician DIY Senior Member
    Jun 15, 2007
    It's stupid and IMO dangerous but NEC allows it.
    Like HJ says, you can't do it in AZ. In some places you can just run exposed cable tacked to the side of the building. :eek:
  14. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Would that disconnect be the meter itself?
    Or inside the meter base?
    Our Main panel is in the basement
    The meter is directly outside - up about 16" on the outside wall
  15. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Why would you say this?
    Very few areas require an outside shutoff. Because you are one of them you think it is stupid not to have it.
    That is like saying Chicago is right for requiring all conduit in a residence and the rest of the country is stupid. :rolleyes:
  16. Alectrician
    Jun 15, 2007
    IMO means "In my opinion"......right?
    I can offer an explanation but it's not really up for debate because it is simply my opinion.
    I have seen numerous fires on cable WITH protection, especially higher amperage protection like water heater/range and AC cable. A fault on an unfused/protected cable would certainly be likely to cause a fire.
    Things are always happening to cables in peoples houses. How many sawsalled cables have you repaired/replaced? Houses are constantly being renovated and often by the homeowners themselves. I think it is only prudent to provide overcurrent protection on any cable run inside a house or within reach of people in normal circunstances.
    A lot of places in the world have seriously substandard electrical systems, You look at the pics from India and think "That is stupid" not because you live in a place with a reasonably safe system but because you know and have seen the dangers involved.
    Chicago?
    It is my opinion that conduit and wire systems are more safe than NM systems but I do think NM systems are safe enough.
  17. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I know it is your opinion. I was just wondering what you were basing this on. That's all.
    I'm not talking about the rest of the world. I am talking about the MAJORITY of OUR country.
  18. Alectrician
    Jun 15, 2007
    Bah!
    Don't make me look up statistics but I will wager that a majority of current installations are not done hillbilly style :D
  19. Speedy Petey
    Jun 16, 2007
    NY State, USA
    Well, I'd be curious to know just how many areas REQUIRE an outside disconnect. I don't think it's many.
  20. codeone
    Sep 5, 2008
    North Carolina
    The NEC doesnt require it. Most places adopt the NEC in this country.
    I would also be curious how many if any really require it. If they do it would be nice to see it in writing ( their statutes )
  21. jbfan74
    jbfan74 Electrical Contractor
    Jun 14, 2007
    Newnan, GA
    All over the great state of GA!
    In the places I have worked anyway!
Similar Threads: Main Disconnect
Electrical Forum discussion & Blog Main Disconnect Seperate from panel? Jun 3, 2009
Electrical Forum discussion & Blog Main Power Supply Move Jun 23, 2016
Electrical Forum discussion & Blog Extending ground wire from main panel Jun 11, 2016
Electrical Forum discussion & Blog Two MC cables into one knockout on main panel? Jun 11, 2016
Electrical Forum discussion & Blog Does a sub panel in attached space need a main breaker? Feb 20, 2015
