Made a mistake...wrong cement
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by froddan, Jul 30, 2007.
  1. froddan
    froddan New Member
    Jun 14, 2007
    Halfway into my drain project I realized that I have used PVC cement for my ABS pipes...do I have to redo everything, or is this still ok?
    It seems to work fine, and I tested to connect two pieces of ABS again using the PVC cement and then tried to remove the abs pipes...but they were sticking together very well...
    I would really hope it is ok...
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    Sorry, you'll have to redo the job. Here's the deal. ABS and PVC are not actually glued in the regular sense of gluing. The so-called "glue" is actually a solvent that melts the surfaces of the pipe and fitting for a few seconds. When you slide the joint together, the two surfaces blend together. The process is properly called "solvent welding". It is much the same as welding metal. One process uses heat to melt the two surfaces the other uses chemical reaction. The problem you have is that ABS and PVC are different materials and each requires its own solvent to melt the surfaces. Although your joints seem to be stuck together, the joint will not hold. I think there is a product that will work on both ABS and PVC, but I have no first hand knowledge of it. Sorry to rain on your parade, but at least you found out before covering the pipes and finding out when the joints failed.
  4. froddan
    froddan New Member
    Jun 14, 2007
    Oh no!
    Oh No!
    I can't believe this....
    I've spent so much time doing this project and now I have to redo everything...
    Does everyone agree that I need to redo this whole thing?
    Right now, three days after I "glued" the pipes together, it is still impossible to tear them apart...
  5. chris fox
    chris fox Member
    May 9, 2007
    near phoenix AZ
    I agree with Gary, you have to redo the job.
    sorry
  6. got_nailed
    got_nailed DIY Senior Member
    Jan 11, 2006
    It will be fine till the pipe flexes. So if it gets some hot water in it or it gets bumped into, and so on. It will not come apart now but with in a few months I will say that you will start to have leaks.
    Gary is right that there is some glue that will work on both. I have used it but only for joining PVC to ABS. If I’m using ABS then I use ABS stuff. If I’m using PVC them I use PVC stuff.
  7. Terry
    Aug 17, 2004
    What would be worse, would be to find this out after drywall and carpets.
    Now that would be a disaster.
  8. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    ALL OF THE ABOVE...I agree in full...you have to redo it...those joints won't hold very long.
    I couldn't say a thing that hasn't already been said above regarding this.
  9. jimbo
    jimbo Plumber
    San Diego, CA
    Your joints may seem to be " glued" but you will probably find that application of very small force will "crack" the bond. You really must start over,
  10. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    I say leave it. In a couple of years it will create work for a plumbing contractor.
  11. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    Read the label and all the fine print on your can *very* carefully and be absolutely certain before breaking out the big hammer. I usually buy "All Purpose" cement for anything other than CPVC, and maybe, just maybe, you have actually done something similar.
  12. froddan
    froddan New Member
    Jun 14, 2007
    Oatey 1-Step CPVC Cement
    Thanks for all responses.
    The kind that I've used is:
    Oatey 1-Step CPVC Cement - a Yellow Can.
    Lo-V.O.C. CPVC FlowGuard® Gold™ 1-Step Yellow
    http://www.oatey.com/apps/catalog/showskus.asp?ctg=1&subctg=2&prodgrpid=184
    What kind of upsets me (except for my own stupidity) is that a worker at HD recommended this when I bought the ABS pipes
    You guys are the pros so I guess I don't have a choice but to start over....it is quite interesting to me that it will brake soon considering it is super tight right now.
  13. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    Abs drain lines??
    I agree with ----LEEJOSEPHO----
    All purpose glue is all purpose glue........
    I hate to be contrary but if this was on
    some common drain lines, wouldent that gule do just fine??
    I have had to tie into old abs and add on with new pvc many times
    with just common OATY MEDIUM PVC glue, with never a problem...
    If they are never under anything but static pressure
    I would venture to guess that those joints would never
    leak and I doubt that anyone could ever pull them apart....
    but it is your gamble....
    why dont you look into that glue you used
    a littel further before you tear it all out.
    if that glue is good enough for high pressure cpvc,
    it ought ot be good enough for a toilet
  14. froddan
    froddan New Member
    Jun 14, 2007
    Some hope...or gamble
    MasterPlumber...
    At least you gave me some hope...and I appreciate it.
    What I have used the 1-Step CPVC cement for is 1 1/2" drain lines from a tub-shower to the main stack and also a sink that connects to the same line.
    It is not very long, but I've installed a clean-out and several turns etc.
    There is certainly no pressure and the drain rests nicely on the studs.
    I'm sure most of the experienced plumbers will say NO, and I appreciate any advice. I guess my positive thinking tells me that the technology used 10 years ago could probably not create such a strong bond as this is today.
    The can says "ALL WEATHER CPVC CEMENT", so it can't be that bad.
    I ran scolding hot water through it to test, and so far so good...but who knows...it might break later
  15. geniescience
    geniescience Homeowner
    Nov 27, 2005
    ditto
    the advantage of redoing it all now while all the steps are fresh in your mind is that the re-do will be a breeze. When you take your measurements you'll say yeah that is what I got last time, and every cut will be easy. Second time 'round you don't have to spend all the time that a beginner DIY spends on microdecisions and hesitation.
    david
  16. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    Oh it can, it's CPVC cement...the solvent weld is a totally different chemical process.
    Effectively you could as well use Elmers glue.
  17. Cass
    Cass Plumber
    Nov 12, 2005
    With the time you have spent talking to everyone about it you could have redone the job.
    Tear it out and redo it.
    The peace of mind will be worth the extra effort and time.
    If you don't eventualy you will have problems and will kick your self for not taking the time now.
  18. cruiser
    cruiser Member
    Jul 24, 2007
    California
    As much of a pain in the ass as it will be,do it again. Everytime you flush that toilet you're gonna wonder exactly where the flush is going....you know you are:)
    It's one of those things,offer it up as my Mom would say:)
  19. Verdeboy
    Verdeboy In the Trades
    Jun 12, 2006
    Don't Touch That Drain!
    Chemist here. (But you don't need to be one to read a label).
    I've got a can of CPVC cement and a can of all purpose cement in my hands.
    They have exactly the same ingredients.
    Solvents: Tetrahhydrofuran, Methyl ethyl ketone, cyclohexanone
    Resin: CPVC Resin 686-48-82-8
    It seems your Home Depot guy knew what he was talking about. The CPVC resin works on ABS, PVC, and CPVC systems.
  20. froddan
    froddan New Member
    Jun 14, 2007
    Hey, looks like I'm getting some supporters here!
    Thank you Chemist!!!!
    It might be a gamble, but I'm a gambler so I am very tempted to wait and see what happens.
    I received some "inside information" from a manufacturer of some of these cement products, and the ingridients are the same, or very similar, and as long as used properly, they will not leak...according to this person.
  21. GrumpyPlumber
    Jun 18, 2007
    Licensed Grump
    ABS solvent:
    "Ingredient: ACRYLONITRILE BUTADIENE STYRENE RESIN
    Ingredient Sequence Number: 01
    Percent: 25-35
    NIOSH (RTECS) Number: AT6970000
    CAS Number: 9003-56-9
    Proprietary: NO
    Ingredient: 2-BUTANONE (METHYL ETHYL KETONE) (MEK)
    NOT a chemist, but seems there are a couple other things in there too.
    I say just use Elmers...heck why not?
Similar Threads: Made mistakewrong
Plumbing Forum, Professional & DIY Advice Homemade faucet with copper pipe Jan 31, 2016
Plumbing Forum, Professional & DIY Advice Are any Toto sinks made on the US? Oct 13, 2015
Plumbing Forum, Professional & DIY Advice Aerator needed on home made copper pipe faucet Jun 19, 2015
Plumbing Forum, Professional & DIY Advice Made a little Boo-Boo Sep 17, 2014
Plumbing Forum, Professional & DIY Advice Who made this Faucet Aug 19, 2014
