Macclean W/S pressure tank leaking
Discussion in 'Water Softener Forum, Questions and Answers' started by teoracer, Dec 27, 2009.
  1. teoracer
    teoracer New Member
    Dec 27, 2009
    new york
    I have a Macclean model # NSM1001 water softener and the pressure tank is leaking around the threads on the top of the tank. Do i have to replace the tank or can it be repaired? Being just after Christmas I am trying to do this as economically as possible. I switched on the bypass and unplugged the softener to stop the leak until I can repair it.....HELP PLEASE
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I have seen tanks crack in that area before. You should drain the pressure off, remove the head and inspect the tank very carefully. If it's cracked you will need to replace it.
  4. teoracer
    teoracer New Member
    Dec 27, 2009
    new york
    Is this something I can do myself? How do I release the pressure in the tank before removing the top assembly?
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    shut the pump off and open a faucet.
  6. Gary Slusser
    Retired
    I teach my customers how to do it all the time. Put the control valve in the backwash position and let it backwash 3-4 minutes.
    Then put the by pass valve in bypass and then put the control valve in the backwash position. That relieves the pressure and fluffs up the resin so it will come out of the tank easier. And you have water in the house if needed. You will need water to get the resin out of the tank and with the pump shut off as has been suggested, you would have none....
  7. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I don't think at this point he wants the resin out of the tank. He just wants the valve head off so he can inspect the tank threads. But even if the tank is cracked, I would replace tank and resin at the same time.
Similar Threads: Macclean pressure
Water Softener Forum, Questions and Answers Looking for info on a MacClean MCA-1J iron filter Jul 7, 2013
Water Softener Forum, Questions and Answers Macclean filter media change...HOW???? Mar 22, 2011
Water Softener Forum, Questions and Answers Water pressure low and water not clear after water softener regenerates Dec 11, 2016
Water Softener Forum, Questions and Answers Low water pressure after finally refilling with salt Mar 10, 2016
Water Softener Forum, Questions and Answers In well pressure tank Dec 2, 2015
