luke warm water
Discussion in 'Shower & Bathtub Forum & Blog' started by dennislewis, Jan 2, 2010.
  1. dennislewis
    dennislewis New Member
    Jan 2, 2010
    I installed a Pegasus 898 056L shower set. I cannot get hot water. The cold works fine and when I rotate the handle to the hot side it is only luke warm.
  2. jadnashua
    Assuming the hot supply is really hot, all new shower controls have a high limit mechancal adjustment. On some, it is a screw, on others it is a lever. You'll need the instructions to figure it out. Normally, you have to take the trim off to reach it. Because summer incoming water is normally warmer, if you adjust it in the summer, it will be cold in the winter, and vice-versa. That's one reason why I prefer a themostatically controlled valve. Set the desired temp, and it works the same winter/summer, end of tank, beginning of tank.
  4. AAnderson
    AAnderson In the Trades
    Oct 25, 2009
    Aptos, CA
    first is the water in your lav sink hotter than in the shower or the same? I assume the lav is hotter because the installing plumber had not adjusted the disc on the valve after setting trim. this typically sets behind the trim and is more or less intuitive. It prevents you from turning a handle beyond a fixed point. It can be lifted off the valve and rotated to the left to give you higher temps.
Similar Threads: luke warm
Shower & Bathtub Forum & Blog Delta shower slowly goes from hot to lukewarm Mar 16, 2015
Shower & Bathtub Forum & Blog Lukewarm water/low pressure in shower (not the everyday problem) Nov 5, 2013
Shower & Bathtub Forum & Blog Only lukewarm water in tub and shower Jan 4, 2010
Shower & Bathtub Forum & Blog Shower Cold/Lukewarm - Sink Hot? Dec 14, 2008
Shower & Bathtub Forum & Blog Problem with lukewarm temp on Pegasus 1/4 turn 1 handle shower/tub Dec 3, 2008
