luke warm water at bath
Discussion in 'Shower & Bathtub Forum & Blog' started by kmp-fxsts, Jan 14, 2007.
  1. kmp-fxsts
    kmp-fxsts New Member
    Jan 14, 2007
    I have a single control mixer for my bath/shower in my 25 year old home. My problem is that I cannot get any more than lukewarm water from it even with the controls at full hot. The sink in the same bathroom performs as normal and provides hot water. Any suggestions?
  2. smartin684
    smartin684 New Member
    May 3, 2005
    Change the anti-scald setting
    If you are getting hot water from the sink, then the problem is probably in the anti-scald setting on the shower handle. Pull the handle off the shower control, and you should see some kind of semi-circular piece with gear like teeth in it. This is ajustable so that you can only let so much hot water in so as not to scald the user. This is adjustable. Try repositioning it so that it allowes more hot water through the valve. There shoudl be a + OR - marking on it. Hope this helps.
  4. norcal1
    norcal1 Plumber/Owner
    Jan 24, 2005
    Sounds like a balancing spool problem...just replace the cartridge and you'll be taking hot showers in no time.
    Good luck.
Similar Threads: luke warm
Shower & Bathtub Forum & Blog Delta shower slowly goes from hot to lukewarm Mar 16, 2015
Shower & Bathtub Forum & Blog Lukewarm water/low pressure in shower (not the everyday problem) Nov 5, 2013
Shower & Bathtub Forum & Blog Only lukewarm water in tub and shower Jan 4, 2010
Shower & Bathtub Forum & Blog luke warm water Jan 2, 2010
Shower & Bathtub Forum & Blog Shower Cold/Lukewarm - Sink Hot? Dec 14, 2008
