Lowboy gas waterheaters.
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by hammerslammer, Apr 22, 2007.
  1. hammerslammer
    hammerslammer New Member
    Dec 10, 2005
    Colorado
    I built a 4-plex in 1985 and had 4 lowboy's in the crawler. The 4 went bad within a few months of each other in 1997 and were replaced. I need to anticipate replacement again and I understand the lowboy's are no longer produced. Space is tight so I'm considering maybe an electric low profile or maybe a tankless?? I think what I have now are 30 gallon and I have not had any complaints about enough hot water. Any advice or thoughts would be appreciated.
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Do a websearch for lowboys. This might be a good space for tankless, though. Maybe even just one for all 4 units.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    low boys still available
    all I put in is Brad ford white low boys
    they are still available, in 30 and 40 and 50
    why in the world would you want to risk trying a tankless
    water heater when you have such good luck with the normal
    trouble free tank type?? especially in a rental unit??
    a good tankless will cost you at least 3 times what a low boy
    will cost, and you WILL have to retrofit the whole place to make them
    work right....
    why tamper with perfection
    if you get 10 trouble free years and no
    complaints from renters???
  5. hj
    low boy
    What is your idea/definition of a low boy? What is the maximum height you can use. Many years ago there were crawl space lowboy gas heaters, but the new ones are about 48" tall.
  6. hammerslammer
    Dec 10, 2005
    Colorado
    Yeah, 48 inches would be too tall for me. I think mine are about 34 to 36 inches. I did a websearch and havn't found anything that might fit. Thanks for the replies.
  7. hammerslammer
    Dec 10, 2005
    Colorado
    Ok I searched and searched and can't find the shorter one. I think i'll be prepared with a lowboy electric for the emergency swapout and maybe in another two years or so I'll have some options that are more clear.
    Is there a chance that the current 4 heaters might last longer than the four installed in 1985??
    Thanks for the help. HS
  8. jadnashua
    22-years is excellent for life of a WH...
  9. hammerslammer
    Dec 10, 2005
    Colorado
    No the first four lasted 12 years. I'm on 10 years on the second four. I'm assuming they will pop in two years?
Similar Threads: Lowboy waterheaters
Plumbing Forum, Professional & DIY Advice Which Electric Lowboy? Apr 8, 2012
Plumbing Forum, Professional & DIY Advice Lowboy under countertop Nov 7, 2011
Plumbing Forum, Professional & DIY Advice Kohler lowboy rebuild tips&tricks needed May 30, 2007
Plumbing Forum, Professional & DIY Advice Can't Find Lowboy Gas Water Heater Jan 21, 2005
