low water px
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by markmark, Feb 5, 2007.
  1. markmark
    markmark New Member
    Dec 7, 2006
    during some bathroom work i capped off the supply lines to my bathtub. Now the taps to my kitchen sink have very low water pressure. All other taps in the house seem to be working fine. any ideas on what happened? could the lines be airlocked?
    thanks for any help
    mark
  2. Cass
    Cass Plumber
    Nov 12, 2005
    when you caped off your lines you turned off the water when you turned it back on did you open the valves all the way? I'm wondering if the shutoff were under the sink as I have seen that. Not air lock. The shutoff valve may have dislodged something that got caught in the faucet when you turned it back on. Some times the washer brakes up and travels down the line.
  4. markmark
    markmark New Member
    Dec 7, 2006
    i used the main shutoff to the house, and kitchen sink is the furthest fixture from this shutoff and was one of the last ones turned back on after the lines were capped
  5. GoTanklessToday
    GoTanklessToday In the Trades
    Jan 11, 2007
    Renton, WA
    Clean the aerator....
  6. Randyj
    Randyj Master Plumber
    Nov 25, 2006
    Alabama
    When you were messing with the pipes...if metal, you knocked crud loose which went to the kitchen pipes as it was washed downstream....if PVC, then when you sawed the pipe the shavings fell down into the pipe and went the same way... all that collects at places like supply lines, valves, or aerators & screens.
  7. markmark
    markmark New Member
    Dec 7, 2006
    Thanks...worked great. simple things that get overlooked:eek:
Similar Threads: water
Plumbing Forum, Professional & DIY Advice New hot water heater/PEX Yesterday at 12:27 PM
Plumbing Forum, Professional & DIY Advice Occasionally hearing water running through vent stack, but no water is running. Wednesday at 6:13 AM
Plumbing Forum, Professional & DIY Advice It's Hot! Drink some more water. Wednesday at 3:38 AM
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice What's in a glass of water? Feb 18, 2017
