Low Water Pressure to Shower only - Tub fine
Discussion in 'Shower & Bathtub Forum & Blog' started by Bumfuzzled, Jan 1, 2008.
  1. Bumfuzzled
    Bumfuzzled New Member
    Jan 1, 2008
    I recently changed out the diverter to our delta shower faucet (push in the wall type). At first, water leaked out of the tub faucet and there was a noticable drop in water pressure to the shower. I originally bought a "universal" diverter and once the leak to the tub faucet was noticed, I returned it and replaced with a Delta original part diverter. That stopped the leak but did not resolve the water pressure issue. There is not a problem with the shower head being clogged as pressure is still low when the head is removed. It takes 3-4 seconds for water to find its way up the shower pipe when it used to be almost instantanous. All was fine until the plastic part of the original diverter broke which caused me to replace the diverter. Pressure to the tub and all other fixtures within the house seems to be normal. I am so confused as to why the low pressure. I just erected new tile on the walls around the tub and really don't want to tear into the wall unnecessarily. (so as not to confuse, all was well after the tile replacement, no plumbing alterations were done)
    Could the little plastic part that broke off the diverter be causing blockage within the plumbing somewhere? If so, where? I'm open to any and all suggestions. I'm obviously not a plumber but otherwise pretty handy. This one stumps me!!!
  2. Bumfuzzled
    Jan 1, 2008
    I've not had any replies...I guess everyone is bumfuzzled like me.:confused:
  4. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    It very possible that apeice of the old divirter is lodged in the faucet body.
    Can you tell me the model# so can find a diagram?You might try taking it
    apart.to see If any thing falls out.Also how old is the faucet?
  5. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Same as above, sounds like washer fragments might be stuck inside the valve body.
  6. Bumfuzzled
    Jan 1, 2008
    I appreciate the reply from both.
    I don't know the model # or age of the faucet. I just bought the house last year. It was built in the mid 80's. I'll try as suggested to disassemble to see if anything falls out. I didn't think that was possible but I don't have any better ideas.
    Thanks again.
  7. AlwaysInHotWater
    AlwaysInHotWater New Member
    Mar 27, 2007
    California
    Sounds like a low flow mixer valve. Is that new also? Restricts the shower head line but not the tub line (otherwise it would take forever to fill the tub.)
Similar Threads: Water Pressure
Shower & Bathtub Forum & Blog New tub/shower set up, not enough water pressure Jan 16, 2017
Shower & Bathtub Forum & Blog Occasional Low Water Pressure Jan 19, 2016
Shower & Bathtub Forum & Blog Concern of water pressure on well for dual shower head setup Dec 5, 2015
Shower & Bathtub Forum & Blog Tub Water Pressure Help... Sep 28, 2015
Shower & Bathtub Forum & Blog Drop in water pressure when flushing toilet Jul 18, 2015
