Low water pressure problem in kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by LBrandt, Oct 10, 2010.
  1. LBrandt
    LBrandt Member
    Feb 9, 2007
    Louisiana
    Hello,
    I have a Price-Pfister 2 handle kitchen faucet (model number 36 H86), and I'm getting very, very little pressure from both the hot and the cold sides. I know that there's no problem with city pressure, because I'm getting excellent pressure from every other faucet in the house. I also know that the input valves under the sink are fully open.
    Isn't it most likely that the problem is in the center (is the correct word "mixer") under the spigot? And if so, what should I be looking to replace there?
    And if it's only in the center, shouldn't I be able to do the repair without turning off the water supply as long as I leave the cold and hot valves closed?
    Thanks,
    Louis
  2. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    It sounds like the aerater, take it off and run the water and clean if necessary.
  4. LBrandt
    LBrandt Member
    Feb 9, 2007
    Louisiana
    I've already done that, and the pressure is no greater even when the aerator is off.
    Thanks,
    Louis
  5. jadnashua
    I don't know if Moen does, but some faucets use a metal screen filter in their hoses to try to keep crud from the cartridge. YOu might take the hoses off, check the flow out of the shutoffs, and check for a filter screen.
  6. LBrandt
    LBrandt Member
    Feb 9, 2007
    Louisiana
    Jim,
    Thanks for the reply, but I installed the faucet myself a few years ago. I used hoses that I purchased from Home Depot. These were not Moen hoses. I think that if the problem were in the hoses, it would be unlikely that BOTH hoses were bad or filled with crud. My thinking is (and I'm not a plumber by any means) is that the problem is in the "center" where the hot and cold come together.
    Thanks again,
    Louis
  7. plumbtired2
    plumbtired2 New Member
    Oct 10, 2010
    wise virginia
    On moen faucets . I noticed they don,t have as good pressure as some others do .
  8. LBrandt
    LBrandt Member
    Feb 9, 2007
    Louisiana
    I DON'T have a Moen faucet. It's a Price-Pfister.
  9. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Does it have a side spray?
    If so how is the flow out of that?
  10. Terry
    Aug 17, 2004
    Is the home 60's or older?
    Sometimes the short sections of galvanized pipes are blocked where it meets the brass shutoff.
    If you disconnect the supply lines to the faucet, you can determine if you have flow before the faucet.
  11. LBrandt
    LBrandt Member
    Feb 9, 2007
    Louisiana
    No, the home was built in 1973. And to answer Redwood's question, I just checked the side spray, and I get good pressure from it. Interestingly, when I use the side sprayer, some water comes out of the center spout.
    Thanks again,
    Louis
  12. Redwood
    Dec 15, 2007
    Service Plumber
  13. LBrandt
    LBrandt Member
    Feb 9, 2007
    Louisiana
    Thanks again Redwood. Your analysis sounds like the right one.
    Yes, I did type the model number in wrong. You're right, it's the H36.
    Yes, I've ordered parts from Price-Pfister before. One more question: If the diverter is under the spout, I shouldn't have to turn the main water off to the faucets, should I? I mean, if I leave the hot and cold handles turned off, there won't be any water coming through when I remove the spout to get to the diverter, will there?
    Thanks again,
    Louis
  14. Redwood
    Dec 15, 2007
    Service Plumber
    Yep just leave the hot and cold handles off and you will be fine.
    The water that is in the gooseneck spout will leak out but that is all.
    It wouldn't be a bad idea to order a new "O" Ring for the spout while you are getting parts as well.
  15. LBrandt
    LBrandt Member
    Feb 9, 2007
    Louisiana
    Louis
  16. Steve Miller
    Steve Miller New Member
    Jul 12, 2010
    I have the same problem and ordered a replacement valve which was plastic but mine is brass. Will the plastic one work? It looks to be held on with a clip, but mine appears to have a collet of some sort holding it in place. I have seen that there are 2 different part numbers from Price Pfister but this is the one I received. I never use the sprayer anyway (it sticks open), can I bypass the valve completely and leave it off?
    Thanks
  17. Steve Miller
    Jul 12, 2010
    Never mind, I just went and got a Moen today and put it in instead of fooling around with the Price, thanks anyway
  18. Price Pfister
    Price Pfister Pfister Faucets
    Oct 27, 2010
    Lake Forest, California
    Quick Follow-up
    Hi LBrandt,
    We just wanted to chime in and see if you're still having problems with your Price Pfister faucet. If you need further assistance, please contact us at pfistersocial@bdhhi.com.
    Hi Redwood,
    Thanks for helping out LBrandt with this issue. We really appreciate it.
    Best Regards,
    The Price Pfister Team
Similar Threads: water pressure
Plumbing Forum, Professional & DIY Advice Fluctuation of water pressure Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Boiler shutting off... water pressure? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Low water pressure upstairs Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water Pressure Regulating Valve Question Jan 14, 2017
Plumbing Forum, Professional & DIY Advice Disinfect new water pressure tank? Jan 8, 2017
