Low water pressure from water coming out of acid neutralizer. Bypass pressure is OK
Discussion in 'Water Softener Forum, Questions and Answers' started by rob742, May 19, 2013.
  1. rob742
    rob742 New Member
    May 17, 2013
    Pennsylvania
    Hi everyone. I had to replace my well pump and pressure tank. After I did this I put my acid Neutralizer in bypass mode until the water coming out of the faucets was clear.It was rust colored so I have waited 3 days for it to become clear. But now when I put the acid neutralizer back into service, I find the water pressure is low. It drops way down if I open 2 faucets at the same time. But if I bypass the Neutralizer then the pressure is good. What could have happened and what can I do to fix this problem? I tried putting the neutralizer in backwash cycle but it did not solve problem. I will try a couple of more backwash cycles.. Anyone have any ideas?
    Thanks
  2. mialynette2003
    mialynette2003 Member
    Nov 24, 2010
    Owner of SWS Systems WWW.SWSSYSTEM.COM
    Ocala, Florida
    Does the pH neutralizer have a backwash valve or is it an in/out type. How old is the media? It sounds as though the media has packed down and is restricting the water flow.
  4. rob742
    rob742 New Member
    May 17, 2013
    Pennsylvania
    It is a Autotrol 440i control. There is a knob that can be turned to backwash position then water comes out of the drain going to the septic pipe. It will backwash for 20 minutes. I have added a 5 gallon container of MB700 calcite corosex media to the little media left about 2 weeks ago. The tank is about 1/5 full of media. I was going to buy more media but now will wait. I tried the backwash and clean cycle 3 times but nothing has changed. The plumber I have been dealing with does not like the calcite corosex mix. He says it gets very hard. The tank is 10 years old and has never been serviced. I have just been adding media to it as it gets low
  5. mialynette2003
    Nov 24, 2010
    Ocala, Florida
    He's right. The media will get hard preventing water flow. You might want to remove the head and check the media. It might be time to empty and refill
  6. Cobra1365
    Cobra1365 New Member
    Feb 7, 2011
    Delaware
    I ran into the same problem recently. Though I empty and refill the tank every year, I never really gave it the thorough cleaning it needed. When I took the "intake line" out of the tank, it was caked with a red clay like substance (Iron residue?). Once I cleaned all of that off and gave the tank a REALLY good cleaning inside, the water pressure picked right back up.
Similar Threads: water pressure
Water Softener Forum, Questions and Answers Water pressure low and water not clear after water softener regenerates Dec 11, 2016
Water Softener Forum, Questions and Answers Low water pressure after finally refilling with salt Mar 10, 2016
Water Softener Forum, Questions and Answers Fleck 7000 intermittent low water pressure Oct 23, 2015
Water Softener Forum, Questions and Answers Low water pressure Jun 2, 2015
Water Softener Forum, Questions and Answers Rusty water pressure tank and water softener resin Sep 24, 2014
