low water pressure after insall
Discussion in 'Water Softener Forum, Questions and Answers' started by jimy, Jan 18, 2010.
  1. jimy
    jimy New Member
    Jan 10, 2010
    canada
    had a new softner installed today is it normal to have a lower pressure at all the taps? maybe its a first day thing?
  2. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    How low are we talking about?
  4. jimy
    jimy New Member
    Jan 10, 2010
    canada
    1030am today
  5. Akpsdvan
    Dec 29, 2009
    Alaska
    If there is a bypass handle on the softener , change it from service to bypass and check the pressure.
    If it is better in bypass that in service, then the system has a problem.
  6. jimy
    jimy New Member
    Jan 10, 2010
    canada
    the installer forgot to open the main valve all the way open. now im about 90% what i had before. is that normal?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    Check the screens in any facit for sand like items that might have stopped at the screen.
    Is the low flow at just one point or at many around the house?
    There will be some pressure drop when any thing is put in the water stream..
  8. Gary Slusser
    Retired
    But with a correctly sized softener you should not notice any pressure loss.
  9. Towman
    Towman Many Hats, few paychecks
    Dec 25, 2009
    sc Wisconsin
    Gary
    My whes-40 manual states a 10 psi drop across input to output. Is this just a max or is this normal? Just curious as to your thoughts.
    Towman
  10. Gary Slusser
    Retired
    That is at a certain gpm flow rate. It is the max gpm at that psi loss. Or you could say you will suffer an X psi loss if you use that much gpm. And usually i wouldn't want to run it at that gpm for more than a few minutes or you will start getting hard water through the softener.
  11. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The specs. for your unit actually list a 12 psig Pressure Drop at Rated Service Flow
Similar Threads: water pressure
Water Softener Forum, Questions and Answers Water pressure low and water not clear after water softener regenerates Dec 11, 2016
Water Softener Forum, Questions and Answers Low water pressure after finally refilling with salt Mar 10, 2016
Water Softener Forum, Questions and Answers Fleck 7000 intermittent low water pressure Oct 23, 2015
Water Softener Forum, Questions and Answers Low water pressure Jun 2, 2015
Water Softener Forum, Questions and Answers Rusty water pressure tank and water softener resin Sep 24, 2014
