low voltage wiring?
Discussion in 'Electrical Forum discussion & Blog' started by GabeS, Jan 26, 2009.
  1. GabeS
    GabeS Remodel Contractor
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    Do you need an electrical license to work with low voltage wiring? ex.) telephone, cable, computer, alarm system, speaker system, etc.
    I heard no from a union electrician. Is that true?
    Also, do you typically need to get permits to run these lines in a preexisting house?
  2. Igor
    Igor New Member
    Dec 2, 2007
    Former Motorhome Electrician
    Oregon
    It depends on where you are. Many states do require licensing for low-voltage work; some don't.
  4. GabeS
    Jan 10, 2007
    Remodel contractor
    Brooklyn NY
    I'm in nyc.
  5. frenchie
    frenchie Jack of all trades
    Dec 30, 2006
    Caretaker
    Technically? Yes. Ever since 2001 when we adopted the NEC. But it doesn't have to be a regular electrician, there's a separate license for low-voltage wiring.
    But I think it only applies to people doing it for hire; you might be okay DIYing for yourself, I'm not sure. Call the DoB and ask.
  6. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    I think there is zero likelihood of dying with less than 47v and less than 18 mA. The NEC seems to relax with less than 30vrms, less than 42v peak and less than 60 vdc.
    The phone line delivers about 56vdc at a max. current of ~170mAdc, but the ringing signal is a bit more than 90vrms.
    I doubt it ever killed anyone.
  7. jadnashua
    Well, if you weren't expecting it, the ring voltage might make you fall off a ladder:D. I know it creates a big surprise if you're holding it when it happens.
  8. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    MD
    Turns out falling or jumping off a 2' ladder dumps as much energy into your body as several bullets. With knees locked, the power dumped into you is very high because the deceleration is very high.
    The Darwin Awards are always lookin' for people!
Similar Threads: voltage wiring
Electrical Forum discussion & Blog weird wiring and wierd voltages on 3 dual switches... Dec 17, 2012
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
Electrical Forum discussion & Blog Exceptable voltage levels for 120V? Aug 15, 2016
Electrical Forum discussion & Blog Does each leg of a 220 line have to have the exact same voltage? Jul 25, 2016
Electrical Forum discussion & Blog Intermittent low voltage on one leg Jul 18, 2016
