Low-voltage switch circuit.
Discussion in 'Electrical Forum discussion & Blog' started by Wet_Boots, Oct 3, 2013.
  1. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    I've seen one or two homes that had wall switches without any line voltage in them. I'm not sure what history would lead to someone having a rack of relays in the basement utility room sending power to ceiling lamps.
    One set of switches I recall involved something more practical, and that's why I'm posting this. These switches were controlling lights in and around a swimming pool, but with all the power coming from the pump room in the pool cabana. I remember these switches weren't controlling relays, but were closing a secondary circuit in some sort of transformer arrangement that I can't recall. I'm pretty sure the closed switch in the secondary circuit made for an increased magnetic field that was used to close contacts, so the function was like a relay, only there was no specific coil with a voltage rating needed to operate it.
    Any of this ring a bell? I rather liked the simplicity of the concept. I saw a data sheet for these low-voltage (or nearly "no-voltage") switching devices, but I just can't remember enough to locate them again.
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Low voltage switching of lights was a big thing years ago. What I have dealt with had a master control located in the master bedroom that controlled all lights.
    What you seem to be describing at the pool is X10 switches.
    http://x10pro-usa.com/
  4. Wet_Boots
    Mar 23, 2007
    Metro NYC
    Definitely not X10. Much more low-tech. Strictly transformer wiring and magnetism. The control circuit wasn't labeled as having any particular voltage or current. It was a UL-listed device, and not a home-brew circuit.
    I should add that this particular device could have predated the transistor - it was that low-tech
  5. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Must be FM
    Was it Magnetism or Hypnotism ?
    http://www.astrologynspiritualism.com/articles_hypnosis.html
    The only system that I have seen like that used SCR's and Flux capacitors.
  6. Wet_Boots
    Mar 23, 2007
    Metro NYC
    I think the circuit diagram would look a bit like two transformers in a series connection, with the low-voltage switch interrupting the interconnection between transformers. I'm sure it's something more subtle, though. There might be a parallel winding involved.
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    It may have been like these,
    http://www.douglaslightingcontrol.com/specifications
    Would be great for a Smart Home.
    Have Fun.
  8. Wet_Boots
    Mar 23, 2007
    Metro NYC
    It must be something that was always obscure. I don't even remember how I located a diagram of its inner workings, in pre-internet days. I don't think it used anything but wires and magnetism to accomplish the task, and it did so without step-down transformers and relays.
  9. bluebinky
    bluebinky Member
    Aug 31, 2011
    Software Engineer
    Santa Clara, CA
    It sounds like some kind of magnetic amplifier.
  10. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    So which is it?
  11. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    This has to be one of those 0 phase systems.
    Sounds like FM.
  12. Wet_Boots
    Mar 23, 2007
    Metro NYC
    My memories just can't quite connect the dots. Since there was supposedly very little power/voltage in the control wires, I think that probably rules out a circuit where you can see a turns ratio on a magnetic core. And yet, closing the circuit represented by the control wires would alter a magnetic field enough to open and close power contacts.
    You see the circuit diagram, and you get it, is about all I can add. And that even goes for my grudgingly obtained schooling in magnetics, where a weber is a charcoal grill, and a henry is the home run king.
  13. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    Sounds like an old R-7 relay system. 24V to switch boxes and remote latching relays to control the lights. Great system. Rugged, reliable, and flexible.
  14. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Some of the newer systems are pretty neat.
    If you run DC you can go off grid without the need of inverters.
    With all of the Smart Meters used now a days, Remote controlling over the internet is getting popular.
    Have Fun.
  15. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Here we are in agreement and one of the best on the market. I own two of them, one charcoal the other gas
    Now I must give a little rebuttal on this as Henry is the best darn rifle ever made
  16. Wet_Boots
    Mar 23, 2007
    Metro NYC
    A google search is not much use. Too much product out there accomplishing the same task with modern electronics. I might someday find an invoice that gives me the location where these switching units are probably still in place, and I might request a peek at them.
  17. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I was very disappointed in the new Weber grills.
    The last one that I bought was made in China and you could tell it, compared to the old stuff.
    It cost over $100 and the other knockoffs of the same design were $40, but I bit the bullet and got the Weber Kettle.
    They were probably both made in the same China factory.
  18. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Two words, Touch plate. Look it up I found it and I have worked them and was a PITA
  19. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    What a Great RFI Generator.
Similar Threads: Low-voltage switch
Electrical Forum discussion & Blog Connecting low-voltage conduit to electrical boxes Jun 21, 2008
Electrical Forum discussion & Blog Transfer switch connections Mar 22, 2017
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Mar 19, 2017
Electrical Forum discussion & Blog Lights will not turn on using 3 way switch Mar 5, 2017
Electrical Forum discussion & Blog Activating Pump via low voltage switch input Feb 11, 2017
