low voltage light question
Discussion in 'Electrical Forum discussion & Blog' started by richrc1131, Aug 13, 2013.
  1. richrc1131
    richrc1131 New Member
    Apr 16, 2008
    Central Connecticut
    I have a ceiling light that has a loose connection between two of the segments. This is one of those low voltage lights.
    What happens is that the light randomly cuts off. If I squeeze that connection point, the light will stay on.
    The connecting area has a small metal clip on the top and one on the bottom (with a single plastic cover) that bridge the gap. They seem to fit snug but I guess not snug enough to keep the connection. When I squeeze the sides of the plastic cover, it comes on.
    There is a screw in the plastic peice that appears to be for tension, but doesn't fix the problem.
    Is there an inconspicuous and safe way to connect these two segments?
  2. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Those things are known for failing like you describe. Not much to do but replace it.
  4. richrc1131
    Apr 16, 2008
    Central Connecticut
    Found the problem with the light fixture
    I discovered the problem. This device is made up of several segments. Each segment needs to be in physical contact (end to end) with the other. They are loosely joined together by what looks like a 3 sided folder peice of metal and a plastic surround which has an adjustment screw on it. This adjustment screw doesn't appear to do much.
    What happens is the two segments appear to work their way away from each other and have to be moved back into place.
    I've included a picture (best I coud do) of the connection point.
    How can I secure these two segments together without making it look too obvious.?
  5. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Buy a new light
  6. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That would be a great Idea.
    It sounds like the Track was not installed properly.
  7. jadnashua
    Too much stuff like this is made in China...now, some of it may be designed here, but if they don't hold them fully accountable on production and QA/QC, what you end up with is crap. They can make some great stuff, but often, it's not! Depends on who designed it and is watching over the process. Garbage in, garbage out. Good stuff tends to actually cost a bit.
  8. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    That is what I was thinking.
    Could probably take it back to WM and get a refund.
Similar Threads: voltage light
Electrical Forum discussion & Blog opinions on what to do with house with low voltage lighting setup Oct 12, 2012
Electrical Forum discussion & Blog trouble shooting low voltage control operates high volt can lights Jul 13, 2011
Electrical Forum discussion & Blog Flickering lights on circuit with low voltage and line voltage bulbs Apr 18, 2011
Electrical Forum discussion & Blog Low voltage light flicker problem Jun 13, 2009
Electrical Forum discussion & Blog Lights flicker and Voltage Drop Question Dec 16, 2008
