Low Pressure
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by Lance725, Jun 5, 2006.
  1. Lance725
    Lance725 New Member
    Jun 5, 2006
    As of last Wednesday my sprinklers did not work. After a lengthy investigation (pump start, breakers, wiring, timers, etc) I came to the conclussion that my 17 year old well pump had died. We replaced the pump with the same size as the previous one and water flowed. My problem is that stations 1 and 2 have a very low water pressure while 3 and 4 have the same pressure as before. We thought that the valves to these two stations maybe clogged but we arent sure. Any ideas or suggestions?
  2. Pumpman
    Pumpman Pump Sales
    Apr 12, 2005
    Owner - R.L. Peeks Pump Sales
    So. Cal
    It's very possible that scale, rust, etc., came loose during the installation of the new pump and is causing a problem with the zone valves on your irrigation system.
    Most valves have either a "jar top" that unthreads to remove the top, or screws that hold the top on. Inside, you'll find a spring and a diaphragm. Sometimes scale will get into this diaphragm, and won't allow it to function properly. Pay attention to the spring when you remove the top and be sure to put it back just the way it came out. The diaphragm will probably stick to the bottom half of the valve. Peel up one side of it, and it will come loose so you can clean it.
    Last, make sure you reinstall the lid in the same position that you found it. There's a tiny hole that the solenoid fits over.
    Ron
Similar Threads: Pressure
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates 55 minutes ago
Pumps and Tanks Well Forum & Blog. Water is life. Helplease....Sprinkler pump and pressure tank Yesterday at 7:51 PM
Pumps and Tanks Well Forum & Blog. Water is life. Alternative way to plumb/operate pressure switch (moving tanks)? Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well head pressure relief valve Feb 6, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Want to change well tank pressure Jan 27, 2017
