Low pressure thru faucets
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by redfed, Oct 31, 2004.
  1. redfed
    redfed New Member
    Oct 31, 2004
    Yesterday, I replaced the washers and seats in my old Price-Pfister tub faucets, in an attempt to stop the continuing drip. The drip has now stopped, but I've noticed that when the hot water is turned on, the flow is good until the water heats up, then decreases. I have to adjust the handle several times to compensate for this. This did not happen before changing the washers. I did not swap the valves, nor did I make any other changes. The only thing I can think of is that the washers are swelling and blocking the flow.
    Any suggestions/advice would be appreciated!
  2. Deb
    Deb Plumber
    Sep 5, 2004
    Idaho
    Deb
    Did you use the correct washers and seats? Make sure the screw is tight. Also, when you reinstall a stem, you need to make sure that the stem is in the "open" position--the washer part of the stem should be against the stem body and not screwed out when reinstalled. You may have gotten some debris in there too that takes about the same time to slow the flow as it takes to get the hot water, but that is a far less likely scenario. I would pull the stem and check the washer and the screw.
    Deb
    The Pipewench
  4. redfed
    redfed New Member
    Oct 31, 2004
    Thanks, Deb.
    I'm sure that I have the correct seats, as the package indicated the were for PP applications, and I matched them up to the old seats that I took w/me to the hardware store.
    As far as the washers, I'm not sure. There were several different washers that fit in the washer section. They were different colors and had a letter following the size. I used a Korky beveled washer. I used flat washers in my wife's bathroom, and her's has the same problem, only on the hot water.
  5. jimbo
    jimbo Plumber
    PP showers were designed to use flat washers. Beveled washers reduce the clearance, and if they swell at all you have a problem. The different colors of washers are different rubber compounds. Black is the softest. I usually use blue or red. WHites are too hard.
Similar Threads: pressure thru
Plumbing Forum, Professional & DIY Advice Pex, Bathrub and Water Pressure Sep 25, 2007
Plumbing Forum, Professional & DIY Advice Pressure testing copper pipes Saturday at 6:33 AM
Plumbing Forum, Professional & DIY Advice Is it a water pressure or water heater problem? Sep 23, 2016
Plumbing Forum, Professional & DIY Advice Simple way to connect pressure gauge to CPVC Sep 15, 2016
Plumbing Forum, Professional & DIY Advice Low Water Pressure at Times Sep 8, 2016
