Low Pressure / Shallow Well Pump
Discussion in 'Irrigation / Sprinkler Forum' started by sgw0989, May 12, 2008.
  1. sgw0989
    sgw0989 New Member
    Apr 13, 2008
    PRODUCT DESIGN ENGINEER
    Grand Haven, MI
    Looking for some information on my new Sprinkler System, I just installed a new 2hp shallow well pump, I only have Zone 1 completed it consist of
    [6] Nelson 6000 Series Heads (Gear Drive) 3/4" inlet coming off of a 2" main to a 1-1/4" elbow reduced to 3/4 to the head"; inthe open part of the yard
    [12] Nelson small popups coming from a 2" main to 1-1/4" line with [12] inline 1-1/4"x1-1/4" x 3/4"[fipt] T's reduced to 1/2" head; near the house for the flower beds
    I turned on the pump got the pressure to 45-50 psi then opened the valve and it dropped down to 10-15 psi. The small popups seem to be ok but the gear drive units seem to be very low pressure and do not shoot very far, I beleive this has to do with the low pressure. I bought the extra HP pump hoping this would fix any issues with low pressure. What did I do wrong or did I forget something...I'm pretty new to sprinkler systems so please help.
  2. sgw0989
    sgw0989 New Member
    Apr 13, 2008
    Grand Haven, MI
    UPDATE: I GOT THE SYSTEM IN, IT PUMPS GREAT LOTS OF PRESSURE AND WATER WHERE IT IS NEEDED, I REMOVED THE CHEAP CHINESE GALVANIZED PIPE FROM THE CHAIN HARDWARE STORE AND REPLACED IT WITH PVC FROM THE GALVANIZED PIPE COMING OUT OF THE GROUND TO THE PUMP AND THEN OUT TO EACH ZONE, ALL ZONES ARE CONNECTED PROPERLY AND THE TIMER IS SET CORRECTLY, MY ISSUE NOW IS THE PUMP IS LEAKING PRESSURE WHEN IT SETS FOR MORE THAN 30-50 MINUTES SO IT WILL GET TO A STAGE WHERE IT KICKS ON AND OFF CONSTANTLY BUT NEVER BUILDS PRESSURE WITH ALL THE VAVLES CLOSED. I CAN'T USE THE TIMER BECAUSE I CAN'T LEAVE IT ALONE FOR MORE THAN 30-50 MINUTES. IT IS LEAKING PRESSURE FROM THE PUMP HOUSING IT IS A PLASTIC HOUSING WITH PVC THREADED INTO IT...WATER DROPS COME OUT VERY SLOWLY WHEN ITS RUNNING AND ONLY AT THE 2 PORTS ON THE PUMP. WHAT KIND OF PRESSURE DO I NEED TO HOLD WHILE THE PUMP IS OFF? WHAT CAN I USE TO SEAL THIS PVC THREADS, IM CURRENTLY USING TEFLON TAPE AND WAS READING IN THE PUMP MANUAL NOT TOO USE ANY KIND OF PIPE PUTTY BECAUSE IT MIGHT DAMAGE THE PLASTIC HOUSING?
Similar Threads: Pressure Shallow
Irrigation / Sprinkler Forum How to calculate pressure to choose water pump Dec 26, 2016
Irrigation / Sprinkler Forum Wilkins 975xl Flow/Pressure Issues Oct 21, 2016
Irrigation / Sprinkler Forum Irrigation pressure regulator adjustment : lock nut is too tight Jul 9, 2016
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
Irrigation / Sprinkler Forum Well pump just bubbling, no pressure May 22, 2016
