Low Pressure Out of GE Smartwater Softener
Discussion in 'Water Softener Forum, Questions and Answers' started by Phillbo, Nov 23, 2010.
  1. Akpsdvan
    Akpsdvan In the Trades
    Dec 29, 2009
    Business owner/service and sales
    Alaska
    Saddly Sears and GE and Polar star units are made cheep and for the most part do not have a long life... Corp would rather have you buy a new unit every few years and fill the junk yard or land fill...
    Fixing is an idea but... fix now and replace in 1-2 years because of other breaks?
    There is a way of using the tank that you have and most likely most if not all of the resin and with the changing of the valve and brine set up having a good working unit for much longer than the GE...
  2. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    And the the spinkter says 'what'?
    Share the love.
  3. Gary Slusser
    Retired
    Meaning that you could/can buy a clamp on tank adapter for your non industry standard (clamp on) resin tank that has an industry standard 2.5" x 8 thread opening for industry standard control valves, and swap your GE for an Autotrol, Fleck or Erie control valve. IIRC you would need a new distributor tube and possibly brine line and if you have a cabinet model, you can't reinstall the softener's cover. I used to do things like that for customers 20 yrs ago but quit when you can buy a whole new softener online for about what swapping control valves costs.
  4. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    Are there any truly good units available for 400-500 dollars ?
    After pulling the top filter out and replacing, my pressure has returned to normal but I don't think the system is working as it should .. shower water just does not have the soft 'feel'. How do i test it ?
  5. Gary Slusser
    Retired
    Pour 3 gallons of water down into the water in the bottom of the salt tank (not through the salt) and do a manual regeneration, then repeat with no water usage during or between the two. That should solve the problem.
  6. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    by 'not through the salt' do you mean i need to remove all the salt from the Brine (salt) Tank before adding the 3 gallons of water and running the regens ? Or do I add the water by pouring it in the top of the black tube that houses the Brine System ?
  7. Akpsdvan
    Dec 29, 2009
    Alaska
    I would leave the salt in and adding 3-4 gallons either over the salt at the edge or down the brine well.. either way will work.
    But I am not sure why one would when the GE/Sears unit adds water at the start of the reg cycle.
    If you where to hold off on water use for 5 hours and did 2 back to back regens that most likely will clean up the resin.
  8. Gary Slusser
    Retired
    Phillbo, it means pour the water into the water in the bottom of the salt tank (down the brine well, where the float is, or any other way you can but you don't remove the salt because you don't have to). BTW, you add it again after the first regeneration also.
    If you pour it down through the salt, you can cause a salt bridge as the salt above the water line dries out later and sticks together; especially with the use of pellets but with crystal also.
    All softeners add the volume of refill (pre or post regeneration) water based on the lbs of salt to be used per regeneration.
    The three gallons = 9 lbs, plus whatever his dose is currently gets him very close to 15 lbs for his usually not much more than 1 cu ft cabinet model softner.
    Next to none are set to use the max of 15 lbs/cu ft of resin. So when a softener has not been regenerated properly and there is hard water breakthrough/leakage, you need to regenerate the full cuft volume of resin to it's maximum K of capacity, hence the max of 15 lbs per cuft of resin twice must be used or you don't regenerate all the resin back to max capacity. And if not then later the softener is prone to hard water breakthrough/leakage although it is operating properly.
    If he doesn't add the 3 gals (= 9 lbs) the softener only uses whatever lbs of salt (K of capacity) the control valve is programmed to use and he doesn't regenerate all the resin back to maximum capacity.
  9. Phillbo
    Phillbo Member
    Nov 24, 2008
    Arizona
    Thanks again for the advice !! I'll give the double regen a try as soon as possible.
Similar Threads: Pressure Smartwater
Water Softener Forum, Questions and Answers Water pressure low and water not clear after water softener regenerates Dec 11, 2016
Water Softener Forum, Questions and Answers Low water pressure after finally refilling with salt Mar 10, 2016
Water Softener Forum, Questions and Answers In well pressure tank Dec 2, 2015
Water Softener Forum, Questions and Answers Fleck 7000 intermittent low water pressure Oct 23, 2015
Water Softener Forum, Questions and Answers Pressure Loss Aug 12, 2015
