low pressure on hot side of shower faucet only
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by td3201, Jun 19, 2013.
  1. td3201
    td3201 New Member
    Jun 19, 2013
    Omaha, Nebraska
    Hello,
    I have a low-use shower faucet that has a problem where the hot side pressure is extremely low. The faucet is in the basement on the other side of the wall from the hot water heater so there is only a few feet of pipe we're dealing with here. The rest of the house is fine. Here's what I have done.
    1. Pulled the Moen cartridge and ran the line without the cartridge and it seemed like a lot of water came out when I turned the water main back on.
    2. Replaced the Moen cartridge
    I am kind of stuck here. It can't be the head or the line to the head because the cold side seems to have good pressure. If hot water came out of the opening fine without the cartridge then the lines behind the valve are fine. Any ideas?
  2. asktom
    asktom Member
    Nov 9, 2009
    Victor, MT
    It sounds like restriction on the hot side between the cartridge and the spout. Try backflushing. Turn off the hot at the water heater, pull the hot cartridge, cover the end of the spout with your thumb and turn on the cold slowly.
  4. td3201
    td3201 New Member
    Jun 19, 2013
    Omaha, Nebraska
    It's a Moen single handle cartridge. Sorry, left that detail out.
Similar Threads: pressure side
Plumbing Forum, Professional & DIY Advice Need to decrease pressure on the cold side Apr 16, 2016
Plumbing Forum, Professional & DIY Advice Little to no Pressure Hot water side Mar 8, 2016
Plumbing Forum, Professional & DIY Advice Delta Thermostatic Valve / trim - hot water side has lower water pressure Apr 10, 2015
Plumbing Forum, Professional & DIY Advice Regulating outside hose/water supply pressure Dec 8, 2014
Plumbing Forum, Professional & DIY Advice water hammer on supply side of pressure tank Sep 20, 2014
