Low Pressure mystery
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by dpw-ct, Dec 3, 2012.
  1. dpw-ct
    dpw-ct New Member
    Feb 18, 2012
    I have just installed a new bathroom and am disappointed by the low pressure in the stall shower. Wondering what might be wrong. There does not appear to be any clog or low flow device in the shower head.
    -- I have a private well with pressure tank
    -- Shower is approx 28 vertical feet from the well tank in my basement.
    -- Pex home run to manifold 1/2 inch to bathroom
    -- Mixing valve is Rohl HY19BO
    -- 1/2 copper from mixing valve to shower head and hand shower (have a shut off for each - and we have low pressure even when just one is in use)
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    You don't say what pressure you have at the tank but you will lose 12 PSI over that height alone plus whatever losses through line resistance. Add to that, modern showers are mandated by legislation to be low flow.
    You might consider raising the pressure at the tank.
  4. dpw-ct
    dpw-ct New Member
    Feb 18, 2012
    Thanks for the quick reply. The switch is 30/50 I checked the pressure gauge on the well tank it is reading 50 psi. Do you think I need to raise the pressure or could there be another explanation. If I should raise it can you tell me how to go about that.
    Thanks
  5. jadnashua
    There are two adjustment screws on most well pressure switches....one adjusts the max and the other adjusts the spread...or, you could swap the pressure switch for say a 60/40 that is already adjusted.
    Today's valves and showerheads tend to be lower flow than the older ones. 1/2" pex is closer to 3/8" copper, but still should provide more volume than needed for ONE showerhead.
  6. dpw-ct
    dpw-ct New Member
    Feb 18, 2012
    would I need to adjust the air on the tank as well?
  7. hj
    "low pressure" is a subjective evaluation. Use a gauge to get the "real" and exact pressure, then we can tell you what, if anything, to do.
  8. dpw-ct
    dpw-ct New Member
    Feb 18, 2012
    Thanks will do - any heads up on what pressure reading would be good?
  9. jadnashua
    Most valves are designed to work with a minimum of 30-40# or so (some lower). Now, that doesn't mean you'll love their operation at that pressure, but that they'll work. Most people are satisfied with 40-50#. Codes require it to be limited to 80psi - higher and it could just shoot a glass out of your hand when filling it at the sink!
  10. hj
    The pressure should be close to what it is coming into the house. IF both are almost equal and BOTH are low, then you have an external problem, especially if it starts high and then drops to low.
  11. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Are you forgetting to account for the 28 feet of rise at .43 PSI per foot?
Similar Threads: Pressure mystery
Plumbing Forum, Professional & DIY Advice Pressure reducing valve is leaking... can i maybe just remove it? Feb 13, 2017
Plumbing Forum, Professional & DIY Advice Fluctuation of water pressure Feb 3, 2017
Plumbing Forum, Professional & DIY Advice Boiler shutting off... water pressure? Feb 2, 2017
Plumbing Forum, Professional & DIY Advice Low water pressure upstairs Jan 24, 2017
Plumbing Forum, Professional & DIY Advice Water Pressure Regulating Valve Question Jan 14, 2017
