Low pressure in one zone.
Discussion in 'Irrigation / Sprinkler Forum' started by Burleybutt, Jul 13, 2011.
  1. Burleybutt
    Burleybutt New Member
    Jul 13, 2011
    Texas
    Howdy, this is my first post. Sprinkler systems are a new thing to me and I would appreciate some help. I have an 11 yr. old Hunter System with 3 zones. One of the zones developed low pressure and some of the heads don't work at all. I tried digging out a few sprinklers to clean them but it didn't help. I can hear a knocking noise but can't isolate it. There are two valve boxes in the ground, I assume one for each zone. I've read that solenoids can be a cause for low pressure rather than clogged lines. Are they located in the zone boxes, and if so, should I be looking at replacing them? Any help will be greatly appreciated. I live in Texas and my lawn is burning up. Thanks!
  2. mike1059
    mike1059 irrigation tech.
    Jun 6, 2011
    irrigation tech. for a landscape company
    Portland, OR
    The solenoid is located on the downstreem side ot valve. On a hunter valve it will be round and sticking up from the top of the valve. If you turn each solenoid counter-clockwise to open the valve you will know wich zone it is and if the low pressure zone comes on at full pressure the solenoid is bad and needs to be replaced. If the zone is still at low pressure open the flow control knob in the center of the valve.
  4. Burleybutt
    Jul 13, 2011
    Texas
    After doing some research I checked the soleniod in the low pressure zone and found it to be faulty. Good thing I also bought a diaphram because the water was still running when shut off. Put in a new diaphram and problem is solved. Thanks Mike.
Similar Threads: pressure zone
Irrigation / Sprinkler Forum No pressure in line on one Zone May 31, 2016
Irrigation / Sprinkler Forum 5 zone system: one zone has low pressure/spray.. Jun 14, 2014
Irrigation / Sprinkler Forum not enough pressure in all zones May 9, 2011
Irrigation / Sprinkler Forum Low pressure on one zone only Jun 7, 2009
Irrigation / Sprinkler Forum Loss of water pressure in 1 zone Feb 25, 2009
