Low pressure in faucet, not spray
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by milotcat, Dec 6, 2008.
  1. milotcat
    milotcat New Member
    Dec 6, 2008
    I have a Pegasus Kitchen faucet, dont know the model number. It is a single stem with control bar and sray attachment. Pressure is getting lower and lower from the stem but spray is fine. I took off the aerator, but the pressure remains the same. Any ideas?
    Someone told me there is a spring that may be bad. Is this a difficult job? As u can see, I'm not very plumbing-wise, but will try anything, unless i would make problem worse.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    It may be the diverter that is causing the problem.
    Do you have the original paperwork that came with the faucet?
    It is a Home Depot House Brand and all roads in research lead to Home Depot. These most often are Chinese faucets and without the original paperwork figuring out exactly which part number you need can be fun.
    Personally I would rip it out and install a Delta or, Moen faucet in its place.
    You can talk to smockman at 1-888-328-2383. Maybe you will get lucky and talk to someone there that can help you.
Similar Threads: pressure faucet
Plumbing Forum, Professional & DIY Advice Installing a new faucet, pressure seems too high going from Flowtite piping into new metal piping Mar 15, 2016
Plumbing Forum, Professional & DIY Advice Low water pressure in newly installed kitchen faucet Feb 25, 2015
Plumbing Forum, Professional & DIY Advice Very low water pressure after replacing kitchen faucet and no hot water in shower May 15, 2014
Plumbing Forum, Professional & DIY Advice Issues with new kitchen faucet low pressure, great pressure prior Apr 15, 2014
Plumbing Forum, Professional & DIY Advice 10 Yr Old Kohler Taboret LAV Sink Faucet Acts Like Bad Pressure Balancer Mar 28, 2014
