low loss headers
Discussion in 'Boiler Forum' started by cvap, Jul 5, 2014.
  1. cvap
    cvap New Member
    Feb 10, 2014
    Ma.
    While everyone is helping me with my softener issues, I thought I'd ask about another problem I have with a header installed by a local plumber. It feeds two loops, one to floor heat, and one to a Flat Plate exchanger for a 2500 gallon spa. Both work fine alone , but when both are calling for heat the spa temp drops right off. I can correct it with the floor heats mixing valve but then have to change it back or the floor water gets too hot when the spa is not on. Has anyone ever used pre made header/manifold combinations? Or is there something else I can do? 559921a.jpg I saw this Calleffi 509 and it will fit in the tight space I have.
  2. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    Put the spa zone on priority.
  4. cvap
    cvap New Member
    Feb 10, 2014
    Ma.
    Does putting it on priority mean the floor heat won't run when the spa is on? If so, that kinda defeats the purpose of installing a larger boiler. I also have a big towel warmer on the floor loop. The primary pump was an after thought because I complained of this problem. At first, the secondary loop pumps were the only thing that would push water through the boiler. I hate to call someone else and ask them fix another person's problem.
Similar Threads: loss headers
Boiler Forum Mod Con Boiler upgrade, heat loss calc Jan 9, 2015
Boiler Forum Need validation on Heat loss done for a new boiler Nov 11, 2014
Boiler Forum Short cycling because I reduced heatloss through new windows and insulation any ideas to solve probl Nov 6, 2014
Boiler Forum Low loss header question Feb 10, 2014
Boiler Forum Thoughts on low loss header Oct 17, 2013
