Newbie here. Tried a search but not quite finding what I need.
Was having really low hot water pressure at all faucets and showers. Recently it got REALLY low. Looked up some internet stuff and saw some info about draining/flushing HW tank. Before I did that I disconnected the flex pipe coming out of the WH and disconnected the shut off valve. There was build up almost completely blocking the opening.
I chipped that out, trying to be careful not to chip into the pipe. Hooked it back up, turned it on, and the pressure is worse.
Hooked a hose up to the bottom of the tank, opened it, let drain(i'm not sure if this is a flush or drain) Still extremely low.
Funny thing is, I disconnected the flex pipe once with the valve open and water flowed backwards fine. Not sure if this was just water in the system or not. It flowed for a minute.
Do you guys think that debris is blocking the line somewhere? What should i do. Try to dismantle piece by piece until I find the jammed spot? It's galvanized. Is there a way to force water/air back the opposite way?
Any and all help is appreciated. I have a pregnant wife here who doesn't have much patience. She's 9 months and I think I'd better get her some hot water.
Also, If I could actually speak with somebody, that would be great. (323)707-4356
