Low Hot water amount since main valve replacement. Volume seems fine
Discussion in 'Water Heater Forum, Tanks' started by RobPin, Jan 18, 2012.
  1. RobPin
    RobPin New Member
    Jan 18, 2012
    I.T./Web/Marketing/Phone
    Mississauga, Ontario, Canada
    Hi I recently replaced the main shut off valve coming into the house. Since then I'm running out of hot water. This was never a problem before. The volume of water seems OK pressure wise but the amount of Hot water seems decreased and ends in half the time now.
    Any thoughts
    Thanks
    RobP
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If you have an electric water heater and did not turn off the breaker when the work was done, there is a distinct possibility that an element burned out. If you have a gas heater and it was turned off, it may have simply reverted to the default temperature and may need to be raised.
  4. RobPin
    RobPin New Member
    Jan 18, 2012
    Gas heater. Only shutoff cold water valve going into tank during draining of line, but turned it on afterwards. Thanks for reply
  5. Terry
    Aug 17, 2004
    I would check the temperature setting on the gas heater.
  6. RobPin
    RobPin New Member
    Jan 18, 2012
    Will increase. Could solder have traveled down the pipe and be stopped at the cold inlet (theory).
    Rob
  7. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Many water heaters have heat traps in the nipples of the inlet and outlet. Sediment can prevent smooth movement of the ball of the heat trap that could in turn severely restrict the flow but those are not the symptoms you describe.
Similar Threads: water amount
Water Heater Forum, Tanks Hot Water from Cold Tap Mar 19, 2017
Water Heater Forum, Tanks Water heater has no drain pan, what precautions should I take? Mar 6, 2017
Water Heater Forum, Tanks Hot Water Heater Flame Temperature Mar 4, 2017
Water Heater Forum, Tanks Whirlpool 10 year old Water Heater Mar 4, 2017
Water Heater Forum, Tanks Gas Water Heater Explosion? Mar 4, 2017
