low cost radiant heat?
Discussion in 'HVAC Heating & Cooling' started by mrang@neo.rr.com, Mar 8, 2008.
  1. mrang@neo.rr.com
    mrang@neo.rr.com New Member
    Mar 7, 2008
    we are building our retirement home. i will be installing an insulated hot water circulating loop with a gundfos circulating pump. i am using cpvc. near the end of the return (and above) is the master bath shower. this is directly above the steel beam and support post. i am considering running copper lines in the mud under the shower's tiled floor for the radiant heat. this would make the wife very happy. happy wife- happy me! we normally keep our water tank at 125 degrees. is there any reason this will not this work?
    thanx for your time andhave a great day! mike
  2. alternety
    alternety Like an engineer
    Apr 2, 2006
    Washington
    Use PEX for any embedded application.
  4. jadnashua
    Well, think of this - the hot water to the shower would end up being a lot cooler by the time it gets to the showerhead.
    There are some of the electric radiant systems that can be installed there...either put it on a timer or flip the switch before you are ready. Most of them draw in the order of 7-12W per square foot, so it isn't a huge amount, especially in a typical shower. If the room isn't that big, consider doing it all over the floor. You can choose to turn it on and off (it can take awhile to warm up the floor), set it on a timer, or just let the thermostat take care of it. Keep in mind that by the time the floor would get hot doing it as you suggested, you'd probably be done with your shower, or the hot (or wat was left of it) coming down from the top would have warmed it.
    Check out www.johnbridge.com for some thoughts and suggestions on tiled showers.
Similar Threads: cost radiant
HVAC Heating & Cooling Ducted and ductless mini split system installation cost - reasonable? Jan 17, 2017
HVAC Heating & Cooling Package heat pump vs gas pack -costs vs each other to buy Nov 2, 2014
HVAC Heating & Cooling New "high efficiency" system operating costs are HIGHER -- help! Dec 12, 2011
HVAC Heating & Cooling Cost to duct small house for HVAC ?? Nov 7, 2010
HVAC Heating & Cooling Cost to extend gas line in garage? Oct 5, 2010
