Low clearance recessed lights...
Discussion in 'Electrical Forum discussion & Blog' started by locus123, Feb 12, 2013.
  1. locus123
    locus123 New Member
    Sep 2, 2009
    Ontario
    I have low hanging ductwork that is framed in with 1" of clearance (they used metal RC strapping). It's against a wall in an area that needs some lighting. Does such a solution exist where recessed lights are less than 1.5" (0.5" for drywall) deep?
    Originally I planned on using LED lights, but all that is nearby is the light switch box (drywall up the walls, ceiling, etc). I have nowhere to put a transformer, unless I'm allowed to slip it up with the lights, and that assumes it's 1" thick.
    Thoughts?
  2. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Table lamp?
  4. hj
    bulbs and reflectors are more that 1" deep. You are trying to do the impossible.
  5. locus123
    locus123 New Member
    Sep 2, 2009
    Ontario
    Ya, that's what I thought. I was hoping there was a sneaky way to make LED work up there. I know there are some less than 1" deep, but I'm still in trouble with the transformer cause I have nowhere to hide it.
    OK, no worries, thanks.
  6. hj
    IF you found an LED that fit in the 1 1/2" space, I hope you would not need much light there, or had room for a LOT of the lights.
  7. ashleypaxtonn
    ashleypaxtonn New Member
    I think LED's are the solution. I fixed one in my room and the illumination was perfect. Though it takes a lot of trial and error to find the perfect setting.
Similar Threads: clearance recessed
Electrical Forum discussion & Blog laundry: washing-machine clearance from switches Apr 6, 2010
Electrical Forum discussion & Blog Main breaker box clearance Jun 30, 2009
Electrical Forum discussion & Blog Door Clearance? Jan 4, 2008
Electrical Forum discussion & Blog Light Switch wired to receptacle. Can I use to add recessed lights? Mar 19, 2017
Electrical Forum discussion & Blog Recessed light in fire rated ceiling? Nov 16, 2016
