Low angle nozzles
Discussion in 'Irrigation / Sprinkler Forum' started by teamo, Sep 12, 2005.
  1. teamo
    teamo Member
    Jun 26, 2005
    Massachusetts
    I have Hunter PGP rotary heads on my system. I have the regular red nozzles installed that came with the heads. I have seen low angle nozzles (gray) advertised in the literature that came with the heads. What is the advantage of using these? I can only guess that the spray will stay closer to the ground with less of an arc, but when would it be appropriate to use these?
    Thanks Jim
  2. PEW
    PEW DIY Senior Member
    Will allow reach under low branches.
  4. jimbo
    jimbo Plumber
    San Diego, CA
    They are used mostly in areas where heavy winds cause havoc with the spray. A lower angle will have somewhat less distance, but will also be dispersed less by the wind.
Similar Threads: angle nozzles
Irrigation / Sprinkler Forum Old angle valve rebuild kit? Feb 16, 2010
Irrigation / Sprinkler Forum Rotary nozzles - shorter spray length along the edge Sep 28, 2011
Irrigation / Sprinkler Forum What gives? Rain Bird VAN Nozzles Do Not Fully Seat Into 1800 Series Sprayhead. Oct 6, 2010
