Loud Noise switching between spray and rotary heads
Discussion in 'Irrigation / Sprinkler Forum' started by Spaceboy, Jun 19, 2008.
  1. Spaceboy
    Spaceboy New Member
    Jun 19, 2008
    I've searched the site and believe I might have found a few solutions, but none seem to be for the exact problem I'm experiencing so I thought I would post on here in case somebody else had this issue.
    I recently had an irrigation system installed on my 1/4 acre lot. It was done by a reputable sprinkler system guy, and all parts Hunter - so PGP Rotary heads, Controller etc.
    Everything is working great, however every time my sprinkler cuts over from zone 1 to zone 2 it makes a knocking noise in the pipes near where they put tied into my main to run the backflow. The nose lasts < 3 seconds but it is fairly loud, and worrisome to me.
    This only occurs between the switch of Zone 1 and another Zone. So, if I turn off Zone 2, I would hear it between the switch of Zone 1 and Zone 3 instead.
    Zone 1 is setup so it's all of my bed spray heads and all other zones are made up of rotary PGP heads. If I turn off Zone 1 (so no spray heads) I do not get the knocking running the system etc.
    Anybody have any advice? I read where it might possibly be fixed by switching it so my spray zone is my last zone ran by my controller but have no clue how you can do that.
    I wanted to try to do some digging before I called up the person who did the installation.
    Any advice is appreciated.
    Thanks
  2. msgale
    msgale Member
    Sep 28, 2006
    water hammer
    it's probably the rapid turn off of zone 1, the flowing water comes to a quick stop, producing the noise.
    to fix it, you need to add an air chamber to the piping before the shut off valve for zone one. commercially available, or you plumb in a dead-end piece of pipe physcially above your supply pipe, so it doesn't fill w water,but becomes an air cushioin to absorb the force of the flowing water.
  4. Mr_Pike
    Mr_Pike New Member
    Jun 28, 2007
    Nebraska
    Would you describe the noise as Banging? Like pipes shaking banging, or a loud ticking that gets progressively slower?
  5. Wet_Boots
    Wet_Boots Sprinkler Guy
    Mar 23, 2007
    Metro NYC
    Try making the bed zone the last one to water.
Similar Threads: Loud Noise
Irrigation / Sprinkler Forum Watts PVB making loud noise during Irrigation blowout Oct 21, 2013
Irrigation / Sprinkler Forum Valve makes loud clacking/buzzing noise, leaks Jul 18, 2009
Irrigation / Sprinkler Forum New plumbing created water hammer noise in 3 irrigation zones Apr 10, 2014
Irrigation / Sprinkler Forum Pressure vacuum breaker making noise Sep 7, 2009
Irrigation / Sprinkler Forum water running noise Aug 13, 2007
