Randy Gunter
About 9 months ago I bought a 48000 grain water softener. A fleck 5600stx, clack tank 10x54 with resintech 10% crosslink resin. I set it up in my pump house and water is supplied via a submersed well pump from the well into a 250 gallon holding (Aeration) tank then pumped from there thru the water softener to the house. I run 50-70 psi thru the softener to the house. Everything has ran great until about a week and half ago. I noticed the water wasn't soft. I went to look and see what was up and found what was a very large pile of resin on the ground behind my pump house that was discharged from the backwash line. Now the unit doesn't soften water very good. I think it discharged the vast majority of resin out. I checked the filter screens in the unit and the small venture nozzles t0o make sure they were not clogged and they were not. Everything was as clean as a whistle. Why did it do this? Thanks.
