lost pressure
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by nopressure, Jun 21, 2009.
  1. nopressure
    nopressure New Member
    Jun 21, 2009
    I'am a new member and hope someone can help me!
    I put new presure tank in about three mounths ago because wouldn't hold air bladder shot i also replaced presure switch to be safe everything ok untill today...... Presure dropped went and got new presure switch presure gage
    replaced both checked tanks presure holding 38 psi presure stays at 20psi presure gage won,t turn on turned braker on & off drain water from tank started over as if it was just install still 20psi on gage PLEASE HELP!!!!!!!!!!
  2. jadnashua
    Just to be sure, with the pump off and a valve open, the pressure of the tank should be 1-2# less than the low-pressure turn on point of the pump.
    What is your pressure switch set up for?
  4. nopressure
    Jun 21, 2009
    30psi turn on 40psi off
  5. jadnashua
    Most switches are set up for a 20# spread...having it smaller means more pump cycles and can ruin the thing. In your case, with 30# set for the low turn-on, the tank static pressure should be set to 28-29#. Unless you adjusted the switch, it's probably a 30/50 switch. It may be that your pump can't make 50# for some reason, and it overheats and stops at 40.
  6. nopressure
    Jun 21, 2009
    i lower tank presure to 28psi switch still won't kick on ??????????
  7. jadnashua
    The switch adjusment could be off. You sure it is a 30/50 switch and not a 20/40 one? If it's 20/40, then the tank needs to be 18-19#. The switches are adjustable, but a little frustrating to do.
Similar Threads: lost pressure
Plumbing Forum, Professional & DIY Advice Do I have a leak? Pressure lost on PEX Test Mar 6, 2014
Plumbing Forum, Professional & DIY Advice Lost Hot Water Pressure Cause Jul 6, 2013
Plumbing Forum, Professional & DIY Advice Lost water pressure in my whole house after installation of a dishwasher?? Sep 21, 2011
Plumbing Forum, Professional & DIY Advice Lost water pressure Sep 18, 2008
Plumbing Forum, Professional & DIY Advice Lost screw in toilet Jun 20, 2016
