Lost pressure in shallow well system
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by mikerom, Jul 31, 2011.
  1. mikerom
    mikerom New Member
    Jul 31, 2011
    NJ
    Hi,
    I have a 40 year old Myers 1/2 HP HC460 shallow well pump system in my basement that I use for a sprinkler system only.
    Looks like I have 1 1/4 pipes coming from a 4-5" cast iron casing. Lived in house for 30 years with no problems until this spring. Pump used to deliver about 42 psi at pump. It wouldn't shut off at old settings so I had to adjust down to 36 psi. Now when sprinklers are on, pumb delivers a steady 34 psi which isn't enough to lift all all the pop up sprinkler heads in a zone. Water table levels are not an issue. Storage tank is 40 ga. galvanized, no bladder. It has a valve and tube arrangement half way up the tank I think is there to prevent water logging. Any ideas of why I lost pressure?
    Thanks
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Your jet nozzle is clogged up.
  4. mikerom
    mikerom New Member
    Jul 31, 2011
    NJ
    Thanks for your reply. Can it be cleaned or must it be replaced. Is this difficult to do yourself..I'm pretty handy but never worked on
    a pump?
  5. Tom Sawyer
    Tom Sawyer In the Trades
    Nov 29, 2010
    Maine
    It can be cleaned but you will need new gaskets before you start the job and no silicone won't work. It might be difficult to find parts for the old Myers too.
    You can always change the whole pump.
Similar Threads: Lost pressure
Pumps and Tanks Well Forum & Blog. Water is life. Just lost water pressure. Mar 27, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Post-power failure - bladder tank lost pressure - time to replace? Nov 6, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Lost Pressure: Bad Pumptrol Feb 2, 2009
Pumps and Tanks Well Forum & Blog. Water is life. Lost water pressure Sep 18, 2008
Pumps and Tanks Well Forum & Blog. Water is life. Lost Water Pressure Sep 18, 2008
