losing water pressure
Discussion in 'Pumps and Tanks Well Forum & Blog' started by boogsdaddyrick, May 17, 2008.
  1. boogsdaddyrick
    boogsdaddyrick New Member
    May 17, 2008
    I have a question .I have a 6 inch well with a new pressure switch 40/60,new 40 gallon tank, and just replaced a worn out 1/2 horse pump with a new 1 horse. I have my tank pressure set at 38 psi .My question is i am losing water pressure within a few minutes on a garden sprinkler sometimes will drop around 10psi .When i pulled my pump to replace i pulled 160ft. of pipe had water at least 30 to 40 feet of the pipe covered in water.Also have like air sound at pump at the top of the ground then goes away as pressure builds.Any ideas.
  2. Mikebarone
    Mikebarone DIY Senior Member
    Feb 19, 2006
    Phoenix, AZ
    just a thought...
    Do you have a check valve on the water line coming from the well to your jet pump. If you do have one, it might have gone bad. This check valve should prevent the water from going back down the well, when the jet pumps stops. That air sound, (I think) is the just pump sucking air, (not good for the impeller in the just pump).
    I too strongly recommend that a well saver be installed in your system.
    Good luck,
    Mike
  4. speedbump
    speedbump New Member
    Jul 15, 2005
    Water well and pump tech.
    Riverview, Fl.
    I think your talking about a Submersible Pump since you said you pulled a bunch of pipe.
    Do you know what pump the 1/2hp was and what the 1hp pump is. In other words, there are different pumps that go on the same horsepower motors. Buying horsepower does not necessarily mean you will get more water or pressure.
    bob...
Similar Threads: losing water
Pumps and Tanks Well Forum & Blog Xtrol Water Pressure Tank Slowly losing pressure throughout the day Aug 27, 2012
Pumps and Tanks Well Forum & Blog HELP! I keep losing water May 29, 2012
Pumps and Tanks Well Forum & Blog Losing presure w/o any water being used in home May 20, 2011
Pumps and Tanks Well Forum & Blog Shallow well pump losing water pressure with garden hose attached Jun 8, 2009
Pumps and Tanks Well Forum & Blog slowly losing water pressure Feb 17, 2009
