Losing Hot Water Pressure (only)
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by lukus, May 23, 2008.
  1. lukus
    lukus New Member
    Sep 21, 2007
    weird thing happening lately. I've been losing just hot water pressure to the point that there is no hot water running but cold water will run. There will also be a low groaning coming from the pipes when the tap is open. The way I've been temporarily solving the situation is by shutting off the water supply to the (gas) hot water heater then partially drain the tank with a tap open in the basement. Then I close the drain to the tank, open up the water supply to the tank and turn off the tap when i hear the water running. It works fine for a while and then it comes back.
    Any ideas on how to solve this problem?
  2. lukus
    lukus New Member
    Sep 21, 2007
    it happened again last night.
    does anyone has any ideas/thoughts?
Similar Threads: Losing Water
Plumbing Forum, Professional & DIY Advice Hot water boiler is losing pressure/water Oct 20, 2016
Plumbing Forum, Professional & DIY Advice Help! Toilet losing water (internal), wakes me up at night because it refills tank Jul 5, 2015
Plumbing Forum, Professional & DIY Advice Losing Water Surface Feb 9, 2013
Plumbing Forum, Professional & DIY Advice Losing water pressure = leak? Jan 9, 2013
Plumbing Forum, Professional & DIY Advice Drain Noise/Toilet Losing Bowl Water Dec 23, 2011
