Lose of Heat Through Duct Work
Discussion in 'HVAC Heating & Cooling' started by River Rat, Dec 18, 2007.
  1. River Rat
    River Rat New Member
    Aug 13, 2007
    How can one stop the lose of heat through your heat ducts?
    I would like to make my Heat Ducts more effect but would like to know how one can do it?
  2. leejosepho
    leejosepho DIY scratch-pad engineer
    Nov 23, 2006
    disabled-retired industrial fabricator
    I have one duct running through unheated space, and I have wrapped that line with insulation. I have not insulated any of the others because any heat that radiates from them goes into heated space anyway. If you might have a cool/cold room at the end of the line, be sure its return is not in any way obstructed and/or possibly damper other rooms a little to force more warm air out to the end.
  4. jadnashua
    The biggest problem with ducts is leaks. Do NOT use fabric duct tape; it will dry out and leak, plus leave a residue. They make a metal self-stick tape that works quite well for this. It has a paper release on the back so it unrolls off the roll well.
    The ducts can be insulated with wrap or solid insulation.
Similar Threads: Lose Heat
HVAC Heating & Cooling Hot Water heat - Glycol? Other closed-system option? Nov 11, 2007
HVAC Heating & Cooling Floor radiant zones normally open or normally closed Jan 5, 2016
HVAC Heating & Cooling Mini split in a closet ?? Jun 12, 2015
HVAC Heating & Cooling Air handler in closet Dec 13, 2009
HVAC Heating & Cooling closed loop hot water Nov 28, 2009
