Loosening rusty pipes
macminn
I'm replacing my well pump and air pressure tank. I'm a little leary, in that the joints are rusty. Any tips to loosen them? I do have some pics but don't know how to post them here.
R
Rancher
Guest
Rust
Most people here swear by PB Blaster and not WD-40. I would think either will work, and a little heat via a propane torch or heat gun would help too.
Rancher
Cass
Rancher
Thats because PB is a penetrant and WD is for moisture displacement and very lite lubrication.
Gary Swart
Yakima, WA
WD-40 is great stuff for what it is intended for, but it's not a good penetrating oil. I don't know what it is that makes PB Blaster so much better than other penetrating oils, but it is fantastic stuff for rust and corrosion on tight fittings.
Speedbump
Active Member
Riverview, Fl.
Wrenches and hammers. Works every time. All PB does is make my wife mad when she smells the stuff.
bob...
